Results 1 to 15 of 15
20th Dec 2018, 08:08 PM #1Diamond Member
- Aug 2006
- 1,106
Where to source B Belt Pulley from?
Trying to source a B belt pulley similar to the attachment. Total diameter is around 100mm and on the smaller step 70mm.
Would prefer 24mm bore, but smaller bore would be acceptable and can be bored to suit.
Anyone know if something like this could be bought off the shelf?
20th Dec 2018, 08:18 PM #2Most Valued Member
- 4,258
You can get 2step alloy...not sure about cast or steel.
CBC is your friend or any other bearing company.
20th Dec 2018, 08:20 PM #3Most Valued Member
- 4,258
What is wrong with the one shown?
20th Dec 2018, 08:56 PM #4Diamond Member
- Aug 2006
- 1,106
Nothing at all, that motor is 0.75KW, doing an upgrade on the lathe to 1.1KW and would like to use that 0.75KW motor/pulley combination on a drill press.
Is there any issues at all with the alloy pulleys?
20th Dec 2018, 11:32 PM #5human termite
- Jul 2007
- sandstone point queensland
- 69
- 182
will have a look in the morning,I have a large collection of pulleys..........................bob
21st Dec 2018, 06:57 AM #6Member
- Apr 2015
- Tungkillo, South Australia
- 87
- 74
Search ebay. I replaced my lathe's driven pulley a couple of months ago with one similar to this:
https://www.ebay.com.au/itm/SPB-B-se...jN_w:rk:6:pf:0
Charles
21st Dec 2018, 08:22 AM #7Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
From 2010 on a different forum. I've used the same system to make a 2 step pulley.
Making a V belt pulley with a parting blade
21st Dec 2018, 09:47 AM #8
Over the years I've used Ballarat Bearings - they have a pretty good list and can source....will post anywhere and worth a call
21st Dec 2018, 09:51 AM #9Most Valued Member
- 4,258
Alloy pulleys dont last as long as cast...but if you make sure you replace vee belt when it begins to show signs of wear it prolonges pulley life...A worn belt with cracks, not accurately aligned, too loose/too tight wear alloy pulleys much quicker.
21st Dec 2018, 04:19 PM #10Golden Member
- Dec 2011
- 505
+1 for Ballarat Bearings
Bill
21st Dec 2018, 04:30 PM #11Diamond Member
- Aug 2006
- 1,106
Thanks for all the suggestions, I've checked out a few catalogues and emailed a local bearing company with the part number I am after. Only thing I noticed is that it seems 107mm is the smallest diameter available, I would have preferred it to be a little smaller say around 70mm. I'm only looking at single step pulleys at the moment, multiple steps might have to be a custom made thing.
http://www.bearing.net.au/wp-content...-Catalogue.pdf
21st Dec 2018, 05:50 PM #12Diamond Member
- Aug 2006
- 1,106
I also like the DIY approach but sourcing a piece of 100mm bar stock could be difficult or at least not very cost effective. I need to find a good scrappy that sells to the public.
21st Dec 2018, 06:18 PM #13Most Valued Member
Hi Com, are you in a hurry for the Ally bar? Asking, as my supplier of Delrin also has offcuts of Aluminium Bar. Unfortunately he's now closed until early January.
Have you had a look on Ebay, as there are some available online?
21st Dec 2018, 06:53 PM #14Diamond Member
- Aug 2006
- 1,106
Not really in too much of a hurry Kryn, though postage prices might make it uneconomical. I had a quick look on eBay and if I went that way it will end up being cheaper/easier to just buy something off the shelf.
22nd Dec 2018, 12:27 AM #15
I made a few v pullies
http://www.google.com/url?sa=t&sourc...t9Iyf1BPLYtNoA
Pulley and Belt size speed ratio Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 4th Dec 2017, 08:50 PM -
Variable speed v-belt pulley assembly
By Petip in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 22nd Apr 2017, 08:37 AM -
Serpentine belt pulley
By morrisman in forum METALWORK GENERALReplies: 15Last Post: 29th Apr 2013, 12:21 AM -
BS5S bandsaw - changing belt pulley?
By variant22 in forum METALWORK GENERALReplies: 5Last Post: 27th Mar 2013, 08:01 AM -
Small Flat Belt Pulley re Bobs enquiry
By Abratool in forum METALWORK GENERALReplies: 14Last Post: 10th May 2012, 06:46 PM
