Results 1 to 7 of 7
18th Dec 2018, 10:16 PM #1Philomath in training
Anyone thinking of getting a mini-lathe?
Lately I've been watching a bit of 'This Old Tony'. In this episode he talks about the issues he found with a generic mini-lathe
https://www.youtube.com/watch?v=05vUCdzhoe4
Having watched the video, I found it a reasonable examination of these machines without either the outright condemnation or boosting that these machines attract from either side. Worth watching I think if you are contemplating a lathe and wonder whether one of these may do the job (spoiler... Maybe.)
18th Dec 2018, 11:45 PM #2Senior Member
- Perth, Western Australia
- 67
- 362
Thank`s for posting, it brings up some points I had not though of as regards getting a small lathe in the future.
19th Dec 2018, 07:14 AM #3Senior Member
- Jul 2012
- Griffith NSW
- 435
I like how impartial tony was, but after seeing THIS review, theres not a chance Id buy one. In saying that, its not the things that the reviewer says because he is relatively uneducated in what it is he's doing (and I dont begrudge him that, we all started somewhere), the footage is damning enough. Things bent, not fitting correctly, the geartrain damage. It really is a dogs breakfast.
19th Dec 2018, 09:08 AM #4Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
This Tony is funny, like seeing both his hands on ends of the lathe at an impossible stretch, at the beginning.
I had a similar lathe, I'd add that the fit and finish on mine was terrible, and not really improvable.
But one thing all Chinese lathes excel at is the nice satin chrome easy to read dials - wish my Hercus had those.
For similar money though, a used Hercus in reasonable condition is a far better prospect.
19th Dec 2018, 11:57 PM #5Most Valued Member
The small lathe is, as someone once described, a lathe in kit form, assembled to ensure all the parts are there.
It requires dismantling and cleaning thoroughly, then re-assmbling and adjusted to requirements. I had one that was given to me by my Brother, it was a nightmare, couldn't keep drive belts and motor pulleys in it. The gears are plastic which are shared with its other nightmare, the Mini Mill. I've replaced the plastic gears several times, then put in the metal ones, that was great but if you made a mistake, ie. bumped the DOC, it would strip the motor pulley, which is keyed, or strip the teeth off the motor pulley. The circuit board is also a problem, as I've also replaced several of them.
The Mini Mill is in the same catagory. I'm sorry to say that they're biggest POS, I've come across.
When he asked for them back, I nearly got a speeding ticket getting them back to him.
20th Dec 2018, 08:22 PM #6Intermediate Member
- Apr 2016
- 26
I've had a Sieg C3 (mini lathe) and a Sieg X2 (mini mill) for about 15 and 13 years, respectively. Both have worked well and have generally been reliable, both have worked at or beyond their limits. The only time that I have actually broken anything was earlier this year, taking a too aggressive interrupted cut on some cast iron which broke the plastic gears in the headstock.
Sure I've done stuff like added taper roller bearings, tapered gibs to the saddle, which have all improved the lathe, but basically it's a really good small lathe, and the mill is an adequate small mill. Neither machine is perfect, certainly, the finish is pretty basic, the castings are not as nicely finished as some, but this is all pretty superficial stuff as far as I'm concerned.
Before I got my lathe, I enquired of Minitech the cost of an admittedly well optioned Myford, the answer came back at over $15,000 with a (from memory) 6 or 7 month lead time. So I got the Sieg lathe for about $1,000, with roughly the same options/extras as the Myford quote and ex stock delivery.
In my opinion the lathe is better than the mill overall, which had a few issues as delivered. The silly spring thing in an attempt to counterbalance the weight of the head, has been replaced by a gas strut kit from LMS, the silly drive system has been upgraded to a belt drive also from LMS. The "Z" leadscrew lash up is a bit tatty, but I now know it's limitations and it does at least work....sort of. I think that the new mills e.g. the Sieg SX2.7 would be a significant improvement over my Sieg X2, and if I was in the market I would go for a Sieg SC4 over just about any secondhand lathe. Pretty much any secondhand Hercus will have it's age counted in decades now, with a probable really tough life, so buying secondhand can be a challenge, an interesting challenge maybe, but probably a bit risky.
Anyway, just my opinion, in an attempt to bring a little balance..........
cheers
Bill
20th Dec 2018, 08:56 PM #7Mechanical Butcher
- Oct 2004
- 1,898
Thinking about a small second operation lathe
By Michael G in forum METALWORK GENERALReplies: 6Last Post: 8th May 2015, 08:39 PM -
Mini Lathe
By Mutawintji in forum METALWORK GENERALReplies: 32Last Post: 25th Apr 2013, 01:35 PM -
thinking of buying a centre lathe
By tpjamcc in forum METALWORK GENERALReplies: 2Last Post: 27th Apr 2011, 12:45 AM -
By tpjamcc in forum METALWORK GENERALReplies: 1Last Post: 27th Apr 2011, 12:14 AM -
Mini Lathe
By dj_pnevans in forum METALWORK GENERALReplies: 1Last Post: 22nd Apr 2010, 11:46 PM
