Results 1 to 8 of 8
    Mar 2017
    Brisbane
    245
    Default Lowering a bridgeport from a stand
    Hey people I have a small issue - my Bridgeport clone (https://www.machineryhouse.com.au/M5...=Search&s=bm22) is on 2 sleepers about 100mm high each and I need to lower it onto smaller pieces of wood, or just entirely onto the floor. Ceiling height is so low that putting it on the ground will mean the difference between being able to put its head upright and use it, or just have it permanently nodded so it doesnt hit the roof.
    Is there anything you can stick the bridgeport on that will allow it to be lowered gradually, some sort of adjustable feet or a screwing jack?
    I need it lower, obviously I cant use a crane as the ceiling is so low.
    Previously I used a big big lever to just raise and lower one side of the bridgeport at a time but I don't like doing it, I feel like its not great for the base (or my back).
    Jul 2016
    35
    1,522
    Don't stress about the base. Big crowbar and four big wooden wedges, just go around gradually and lower one at a time. I have done it twice today and I'm not a big Gent. Key is lots of leverage
    Aug 2011
    4,779
    Yea, what cask said. If you don't want to commit to the entire height in one go then make a series of blocks of varying heights. Lower the base bit by bit working in a circle, replacing with ever smaller blocks.
    In a training exercise, we lifted and lowered a 1 tonne slab of concrete about 500mm using this technique, although we had 4 people with 4 crow bars, you can do the same in a very controlled and safe way.
    Dec 2013
    56
    1,418
    If you don't want leverage, thread rod, a couple of nuts and a peice of sheet metal to protect the concrete will do it. I doubt you would hurt the base from leverage though.
    Using Tapatalk
    7,189
    Quote Originally Posted by caskwarrior View Post
    Reminds me of how I once got a stump out of a large hole in the ground in our very limited access back yard.
    Levered up one side of the stump and shovelled some dirt underneath, levered up other side, more dirt etc. Eventually I had a filled hole with the stump sitting on top.
    Apr 2013
    Toowoomba Qld
    401
    I used to always use a big old crowbar, a while ago I bought one of these
    https://www.bunnings.com.au/hart-900...-bars_p0057180
    Found them really good for moving machinery, was much better than the straight crowbar. Shorter so didn't have as much issues with clearance and seems to get pretty good leverage. I use some steel blocks or could easily use some wood blocks and a piece of steel plate under the heel of the bar so you can raise it up for higher lifts.
    Looking at your link yours is about 1,100kg, my Bridgeport clone is probably 900kgs so a little lighter but the wrecking bar would make quick work of a job like that.
    Other option is something like remove the lower chip tray, get a length of threaded rod, cut into 4, drop a length through each mounting hold in the base, put a nut on the end between the bottom of the base and the floor. Wind them all up to lift the machine off the current sleepers then go around and lower each a bit at a time until it's lowered onto the smaller bits of timber, should be able to get as low as a nut's thickness.
    I'd seriously be going the pry bar tho, machine is not too heavy that it's not easily do able and by the time you cut a length of threaded rod in 4 the job would already be done with a pry bar.
    Jul 2006
    Athelstone, SA 5076
    4,258
    a mate of mine wouldnt waste his time doing it that way...he'd use black powder...and then waste his time filling an even bigger hole
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Could always try the suck it and see method.
  1. Bridgeport vs Deckel
    By j3dprints in forum METALWORK GENERAL
    Last Post: 18th Aug 2018, 11:04 AM
  2. Bridgeport
    By robbo37 in forum METALWORK GENERAL
    Last Post: 28th Jul 2012, 02:48 PM
  3. bridgeport
    By rfurzer in forum METALWORK GENERAL
    Last Post: 12th Apr 2011, 10:00 PM
  4. Bridgeport mill, how much?
    Last Post: 20th Nov 2010, 01:12 AM
  5. Ebay Bridgeport
    By browny in forum METALWORK GENERAL
    Last Post: 26th Sep 2007, 10:51 PM
