Results 1 to 14 of 14
Thread: Plate rolling
12th Dec 2018, 11:48 PM #1Most Valued Member
Plate rolling
The bloke I help out from time to time is looking at getting a plate roller. Have seen one that has the roll diameter of 110 and a width of 1870. The bottom rollers appear to be very close together, with the top roller above the centre of the 2 bottom rollers.
Would anyone know what capacity this machine could be? The seller doesn't know the capacity, as he only buys and sells used equipment.
Thanks in Advance.
13th Dec 2018, 12:21 AM #2Senior Member
- Perth, Western Australia
- 67
- 362
4 mm maybe up to 6 mm.
13th Dec 2018, 07:11 AM #3Most Valued Member
Comparing the build strength of the components to that of a pan brake, I would have thought maybe 2mm or less, at full width. Maybe slightly thicker with reduce width.
If I were to guess, I would say it was a sheet roller, not a plate roller.
13th Dec 2018, 08:07 AM #4
Just looked on Hare and Forbes site, there 4mm one is 2m x 150 roller. And there 2.5mm one is 2m x 150 roller.
It looks like that one would be 2mm max, maybe 1.6 at full widthUsing Tapatalk
13th Dec 2018, 10:30 AM #5Diamond Member
- N.W.Tasmania
- 1,407
It will depend a lot on what hw wants to roll. There will be almost an order of magnitude difference between some stainless steel sheet materials and say soft aluminium sheets or copper sheet. It may be able to roll 8mm of pure aluminium plate, but something as tough as Bisalloy would be another matter altogether. For those tough materials the limit could be under 1mm for a full width sheet.
13th Dec 2018, 11:22 AM #6
It's far too light to be a plate roll. Definitely a sheet roller.
I would guess at full width no more than 3mm or 4mm sheet thickness.
13th Dec 2018, 12:33 PM #7Senior Member
- Apr 2008
- 269
Agree with everyone, thats a tiddler, used for light thin sheet. Plate rollers are big bastard 3 phase machines with tremendious hydraulic strength to roll plate.
DD
13th Dec 2018, 06:24 PM #8Senior Member
- 67
- 362
I have to admit I know nothing of which I speak.
Out and about today I had a conversation with a gentlemen I use to work with back in the day. After being told that my memory sucks he reminded me that the machine we used had 6" rollers, was heavy framed and struggled with 6 mm.
So I retract my 4 mm may be 6 mm comment.
He suggests, (as others have done) that its probably a sheet roller up to 3 mm.
Tony
13th Dec 2018, 09:17 PM #9Most Valued Member
Thanks everyone for the replies.
I found out today, that what he's looking for is something 2400+ wide and capable of rolling 5mm steel, minimum!!!
He could have told me that before I went looking
13th Dec 2018, 09:32 PM #10
13th Dec 2018, 10:39 PM #11
13th Dec 2018, 11:02 PM #12Most Valued Member
Thanks for that Dave, didn't realise they sold them. Not too bad a price for Chinese made, he'll be running it off a 65kva Generator, if the CNC Plasma cutter's not being used, as I don't think it'll run both of them.
13th Dec 2018, 11:06 PM #13
14th Dec 2018, 01:52 AM #14
Hi Kryn,
I agree with previous posts, definitely a sheet roller, 2.5 mm tops at that width.
I have a small 18" wide set of rolls, It maxes out at 1.5 mm in steel and 2 mm in alloy. Even rolling 12" wide copper into a 100 mm cylinder is hard work on the handle.Best Regards:
Rolling rings from 8mm rod
By Scally in forum METALWORK GENERALReplies: 13Last Post: 1st Jan 2017, 08:13 PM -
Rolling copper
By denncarm in forum METALWORK GENERALReplies: 5Last Post: 27th Oct 2013, 05:15 PM -
Rolling Tailstock Arbor
By barkersegg in forum METALWORK GENERALReplies: 5Last Post: 9th Dec 2011, 08:22 AM -
Rolling brass plate
By SHIPPERS in forum METALWORK GENERALReplies: 0Last Post: 23rd Oct 2009, 06:04 PM -
rolling metal tubes
By piobuilleann in forum METALWORK GENERALReplies: 2Last Post: 29th Jun 2007, 05:22 PM
