Results 16 to 30 of 48
Thread: Squirt bottles
10th Dec 2018, 02:56 PM #16China
- Dec 2005
- South Australia
- 1,658
I had the same problem I now use these have been using one for two years with bleach, kero, turps, metho, window cleaner and it is still goingI have a couple of their standard ones also that are is at least 10 years old and still going although only been used with various commercial spray and wipe type mixtures https://www.adelaidecleaningsupplies...n-us/p856.html
10th Dec 2018, 03:59 PM #17Most Valued Member
- Jun 2012
- SA
- 1,649
10th Dec 2018, 04:00 PM #18Golden Member
- Mar 2009
- 54
- 825
I think the problem with the plastic sprayers is the o rings inside them are not made of material capeable of withstanding exposure to solvents like kero.
The Inox, WD40 and Wurth bottles are the only ones I've found that last with oils and kero. In the past, when I've asked for the Inox or WD40 ones I've been told they are only supplied with the 5lt bulk product bottles, which is how I got the ones I have. The Wurth ones are available individually but are a bit expensive.
An option I plan to try at some point is an old Moffat & Virtue Pest Arrestor, these have leather washers and should be impervious to most solvents you would want to spray around.
Google them and you will get a few links to overpriced specimens from trendy collector shops but you will get the idea and they can be picked up at garage sales or junk shops for less than $10.00.
Greg.
10th Dec 2018, 06:55 PM #19Philomath in training
I got the bottle on the right from a Boating shop I think.
Used for priming liquid fuel stoves.
No problems with Kero or meths...
10th Dec 2018, 06:56 PM #20Novice
- Sep 2014
- Elimbah Qld
- 24
https://www.amazon.co.uk/Refillable-.../dp/B008B6QHB6
I have made my own buy punching a small hole (not drilled ) & soldering on an old tyre valves onto the top side of a used carb clean can or wd40 (elecrtic iron no flame) take the valve out use a small home made funnel fill through valve with half atf/kero or what ever valve back in and about 40psi works well .
10th Dec 2018, 07:05 PM #21
10th Dec 2018, 07:08 PM #22Novice
- Sep 2014
- Elimbah Qld
- 24
grind the rubber off the tubless valve there is a nice brass easy to solder fitting inside
10th Dec 2018, 07:26 PM #23Novice
- Sep 2014
- Elimbah Qld
- 24
a nice way to punch in the hole is with a lathe dead center .Just tap it on the top of the can just to the side of the spray fitting far enough away to not damage it and the heat from the solder wont damage the plastic valve .It will form a nice vee hole to solder the valve into
10th Dec 2018, 08:04 PM #24
Hi Bob,
I take it what you are looking for a chemical resistant spray bottle possibly from these people.
https://austchems.com.au/product/can...cal-resistant/
10th Dec 2018, 08:04 PM #25
10th Dec 2018, 08:19 PM #26Novice
- Sep 2014
- Elimbah Qld
- 24
I haven't but good Idear will give it a go
10th Dec 2018, 08:19 PM #27Most Valued Member
- 70
- 1,514
I remember being told never to clean bearings with kero because it was an abrasive. That was so long ago I can't remember who told me. Anyway, I never use the stuff to clean anything.
Nev.
11th Dec 2018, 09:03 AM #28Most Valued Member
- Healesville
- 2,129
It was a big no no to use kero to clean machines, kero is used as the carrier fluid for lapping cast iron, petrol works well also.
The reason for not using kero to clean your lathe with kero is that if it gets under your saddle it will mix with grit under there and lap your lathe.
Sure, it wont lap much off at first but over a few years.....this was pretty well known by all the old machinists.
The machines ways were only ever wiped with an oily rag.
Kero was also never used to clean hydraulic components.
shed
11th Dec 2018, 09:09 AM #29Senior Member
- Dec 2013
- 201
OK, so you're not saying that Kero is "an abrasive". I'm glad we settled that.
Graham.
11th Dec 2018, 09:25 AM #30Most Valued Member
- Healesville
- 2,129
Graham sorry for the confusion and the waste of yout lunchtime.
What l should have said is kero will be become very abrasive if mixed with grit, in other words the grit will become much more abrasive if it gets kero in it.
cheers shed
Are you worried about leaving your gas bottles on?
By BobL in forum WELDINGReplies: 13Last Post: 5th May 2016, 06:05 PM -
Turning Milk Bottles:)
By ventureoverland in forum METALWORK GENERALReplies: 50Last Post: 14th Nov 2015, 09:16 AM -
Degassing Old Gas Bottles
By DSEL74 in forum METALWORK GENERALReplies: 30Last Post: 17th Sep 2015, 02:20 PM -
welding gas bottles
By brendon17 in forum WELDINGReplies: 11Last Post: 11th Aug 2012, 10:06 AM -
weldcorp 160 mig fitting big bottles help
By freaky349 in forum WELDINGReplies: 3Last Post: 8th Nov 2011, 12:20 AM
