Results 1 to 6 of 6
    Feb 2013
    Laidley, SE Qld
    1,039
    Default OT poppet steam valves
    A few of these NOS valves were dropped off at the Pioneer Village recently, the donor called them "steam valves". They look like a large IC engine valve, 10.625" long, 2.5" head, .625" stem, the head and 4" of the stem appear to be stainless steel, the rest of the stem is steel with surface rust.
    AFAIK which is not much when it comes to steam, steam valves are usually slide valves, if these are steam valves what type of steam machinery would they be used in? The Pioneer Village doesn't have a use for them.
    May 2011
    Murray Bridge S Aust.
    5,959
    I doubt they would be out of a truck, possibly a very large stationary engine.
    They would make very good punches, if nothing else.
    Feb 2012
    48
    They look very similar to valves used in Diesel/Electric Locomotive Engines I used to work on some thirty years ago - ALCO, GE and GM-EMD. So some largish Diesel Engine would be my guess, brand unknown unless there are ID marks or other details. The head of the valve will be some type of Stainless Steel and the Stem will be a Carbon Steel, bonded together by some means now forgotten by me. Often the Valve Seats were Stellite for good life.
    Quentin
    Apr 2011
    se Melbourne
    62
    54
    Steam engines can depending on their design can have not only slide valves, but piston valves (inside or outside admission), rotary valve (Corliss valve engine where the valve rotates) or a poppet valve (eg Sentinal Steam truck).
    As the steam cylinder gets bigger so does the valve(s). I am not able to say that this is or is not from a steam engine. It is possible that it is from a make like Ruston Hornsby that made steam engines before going to internal combustion engines.
    34
    1,080
    Quote Originally Posted by Cueball View Post
    Would friction welding work for something like this? Or do the pieces have to be the same material?
    6,477
    I thought that those valves could have come from a large, probably, diesel engine.
    Re friction welding: That technique has been used to weld all sorts of metals to each other.
  1. Jensen 20G Model Steam Engine Running DIY Steam Hammer
    By Jim Ferrous in forum METALWORK GENERAL
    Last Post: 20th Mar 2016, 05:29 PM
  2. UK Steam
    By wheelinround in forum METALWORK GENERAL
    Last Post: 19th Jun 2015, 11:24 PM
  3. Steam traction fun
    Last Post: 20th Dec 2014, 11:09 PM
  4. refacing auto valves
    Last Post: 4th Nov 2011, 07:31 PM
  5. refacing auto valves on a lathe
    By morrisman in forum THE HERCUS AREA
    Last Post: 29th Jun 2011, 09:32 AM
