Results 1 to 6 of 6
Thread: Removing sheared bolts
2nd Dec 2018, 11:47 PM #1Most Valued Member
We've probably all come across the situation of a sheared off bolt. This clip shows an easy simple way of centring the drill bit. https://www.youtube.com/watch?v=dJfkCj3FWBs
Unfortunately, it doesn't show how to do one that has sheared of flush!!!
3rd Dec 2018, 10:04 AM #2
Good one , Kryn.
I see myself on the lathe drilling out a series of cap head bolts for such an eventuality.
I wonder how hard are the cap heads?
3rd Dec 2018, 11:32 AM #3Most Valued Member
You could use stainless steel cap screws Grahame.
3rd Dec 2018, 04:09 PM #4Member: Blue and white apron brigade
If the bolt is large enough I've been able to grind the top flat and just centre punch and drill a hole in the broken bolt for an easy-out.
Headaches start when the bolts are small or are broken at an angle just below the surface, then I proceed was follows
If the part with the broken off bolt contains a number of coplanar bolt holes I have used the gasket, or the opposite side of the part that shows the bolt pattern, to accurately mark and drill out in/on a piece of 1/4" thick steel the position of any two (unbroken) bolt holes. Also mark out where the broken bolt hole is but drill that to suit an easy-out. Then bolt that piece of steel to the two unbroken bolt holes and the broken bolt hole should like up accurately so you can use that as a drill guide to drill a hole in the bolt for the easy-out.
If there are no other bolt holes available a piece of metal can be sometimes be clamped to the workpiece with the same effect.
3rd Dec 2018, 06:21 PM #5
3rd Dec 2018, 08:47 PM #6Most Valued Member
- 4,890
What do you mean, the wording is all around the place, if new australian I apologise.
Best way to remove these sheared bolts
By eskills in forum METALWORK GENERALReplies: 17Last Post: 24th Jun 2016, 11:08 PM -
Seized Bolts
By yvan in forum METALWORK GENERALReplies: 39Last Post: 24th Sep 2015, 02:37 AM -
HIGH TENSILE BOLTS Vs MILD BOLTS.
By chambezio in forum METALWORK GENERALReplies: 13Last Post: 3rd Jan 2014, 08:25 PM -
Where can I get these T - Bolts
By steran50 in forum METALWORK GENERALReplies: 21Last Post: 21st Jan 2012, 12:59 PM -
best way to cut bolts?
By chylld in forum METALWORK GENERALReplies: 36Last Post: 23rd Sep 2005, 12:36 AM
