Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    6,474
    Hi Eskimo,
    I differ from you BaronJ....I would have looked for the easiest way out...I wouldnt want to have done any more work than what was really needed
    I enjoy the journey Anyway it will look nicer.
  2. #17
    6,474
    I promised pictures, so here you are.
    6" inch rotary table, set up on the mill table square to the back edge.
    The 1/4" inch ball end slot drill in the milling chuck, and zeroed on the centre line and work piece diameter.
    The work piece is screwed on to a MT2 1/125 x 12 tpi, mandrel in the RT centre hole. This is one of the two mandrels that I have for attaching the Myford lathe chuck to other bits of machinery.
    Incidentally the difference in colour between the two pictures, is with and without flash.
    The machining is finished at this point.
    And the end result ! Its surprising how the harrage picks up oil and grease from your fingers.
    I cut eleven grooves in the work, 2 mm deep. I ran the slot drill at 1000 rpm, lots and lots of nice little curly swarf.
    A greasy hand won't slip on that !
  3. #18
    Dec 2013
    Sydney
    201
    Edge of a razor blade? Scotchbrite? A good clean, then hit it with a hot air gun to melt it away?
    All of the above will fix up the appearance.
    Graham.
  4. #19
    6,474
    I'm sure that many of you will remember this item. Well I got the M10 draw bar made and also a brass "T" nut that fits into the end of the lathe spindle for securing the MT2 ER32 collet chuck, and assembled into the spindle. I also found and used one of those foam rings that you find on packs of CD/DVD discs, over the chuck arbour before putting it in the lathe spindle, it seals the gap nicely.
    Anyway I found the time to take some pictures of it this morning prior to starting another little job.
    You can see the foam ring between the chuck and the nose protector.
  5. #20
    Jul 2007
    On the Bellarine
    167
    NIce job John...........how's the run out on the spindle under load with the foam spacer?...........I'd be a bit wary of anything soft like the foam to get a proper seal for concentricity.....but them I'm sure you'd be aware of that ...looks neat.......Lee
  6. #21
    6,474
    Hi Lee,
    The foam ring just sits between the face of the lathe spindle and the back of the collet chuck. There is very little pressure applied to alter the run out.
    I've not been able to detect any run out on the tapered part of the collet seat, just noise as you rotate the chuck. I've just about completed a job that required a 5 - 6 mm collet and on first try had about 4 thou run out 12 mm from the collet face. After removing the collet and carefully inspecting it, I found that it had some bits of swarf between the slots and a small harrage on one of the slots inside the bore. I ended up using a Stanley knife blade and a 6 mm diameter drill shaft to remove it. Remeasuring with a 6 mm dowel pin showed between 0.002 mm and 0.003 mm an inch from the collet face. I did find that the run out varied a little, the more I tightened the retaining nut. It behaved exactly the same with a bearing collet nut.
    In general doing the above confirms my belief that people get poor run out readings without bothering to check if the collet is actually clean and burr free. All the collets that I have checked had swarf and burrs in them. All the swarf could be cleared with a Stanley knife blade.
    This is a short length of aluminium rod that I am about to cut to length.
  7. #22
    Jul 2007
    On the Bellarine
    167
    Sounds like the been knees then and you've overcome your problems which is what it's all about - well done....from experience I know that quite a lot of run out with ER chucks and collets is caused by the poor manufacturing process of them, especially those cheaper versions made in Asia.....generally the cheaper the set, the more quality control issues crop up....most of us are on budgets as we get older and wiser and more contrary too hehe , so we tend to get what we can afford and try to work around the issues......but a good set of collets should be the exception for anyone who uses them.
    I've frustratingly found that the ER holders themselves are generally the cause of most run out problems - usually through incorrect taper, badly cut threads, poorly ground interior, non center cut throats and misaligned draw bar fitting to pull them off center........all types of manufacturing issues that should not happen but I suppose that's why they are cheaper than known quality brands.
    If you have the confidence, make your own holders: better than trying to repair a bad one....plus you can make then purpose built such as face plate mounted for through bores to hold long work pieces......that way there's no more draw bars, no concern for length of material and accurate repeatability - just change a face plate with it mounted on and away you go, so much easier....I no longer use commercial made holders for that very reason......
  8. #23
    6,474
    Good Morning Lee,
    I must have been lucky with my collet holders, the only complaint that I would have about the four that I own is that the three larger ones seem to have quite a rough finish on the internal taper. Evidenced by the amount of noise (flickering of the gauge needle) when trying to measure them. I really don't know if that is intentional or not ! Maybe for oil retention, even using a paper wipe it is quite hard to get them dry.
  9. #24
    May 2011
    Murray Bridge S Aust.
    5,959
    If it has a rough finish on the inside, couldn't you grind it smooth, with a TP Grinder??
    I made a collet chuck for a 7X12 lathe, that came out pretty well spot on, my first go at making something besides a heap of metal shavings.
  10. #25
    6,474
    Hi Kryn,
    I have a new backplate that screws onto the lathe spindle ! I've thought about making an ER32 collet holder to fit it. It is certainly doable. Now whether I can get the taper angles right is another matter. Come to think about it I've got a thick cast iron disc that might have enough meat to make the threaded part with the taper in it.
    Watch this space, another project brewing.
  11. #26
    May 2011
    5,959
    Hi BJ, How I set my taper up, was to put a piece of bar into the chuck, slide on the collet of the correct size, then adjust the compound around till everything lines up with the collet. A dial indicator works best, for setting the angle.
    I actually made a taper turning attachment previously, which helps if you're doing a long taper.
    I can't find the article I wrote about it, unfortunately, but here's the finished article.
    //metalworkforums.com/f65/t121056-project/page-91 posts 1363 and 1364
    I found the nuts vary from manufacturer to manufacturer, so make sure that you don't have several different ones that you want to use.
  12. #27
    6,474
    Good Morning Kryn,
    That is a good idea, I was trying to work out how to get the angles right, last night after I had replied to you.
    I'll go and have a look at the posts you referred to.
  1. Printed Spindle nose cover
    By kwijibo99 in forum METALWORK PROJECTS
    Last Post: 18th Jul 2018, 03:19 PM
  2. Replies: 2
    Last Post: 16th Jul 2018, 05:20 PM
  3. 260 Spindle Nose
    By cba_melbourne in forum THE HERCUS AREA
    Last Post: 8th Oct 2014, 06:38 PM
  4. Info from USA on spindle nose register
    By nadroj in forum THE HERCUS AREA
    Last Post: 17th Aug 2012, 09:11 AM
  5. ER Collet Chuck Spindle Nose Blanks.
    By pipeclay in forum THE HERCUS AREA
    Last Post: 6th Jul 2011, 12:24 AM
