Results 16 to 23 of 23
Thread: 14" Steelfast/Woodfast Bandsaw
2nd Dec 2018, 11:58 AM #16Golden Member
- Jul 2011
- 837
2nd Dec 2018, 05:46 PM #17Philomath in training
That would be one way of doing it (I actually thought of just tacking a rolled ring in place but your way sounds more interesting...)
A ring of 2mm Al would be enough to let you use a 4mm tyre. A ring of 3mm would allow you to even put a crown on it.
3rd Dec 2018, 09:16 AM #18Most Valued Member
- 4,258
4th Dec 2018, 05:27 PM #19Golden Member
- Jul 2011
- 837
I have found a company in Wingfield that will do the job for $50 a wheel. This is more in keeping with my budget I will report on how that goes when I get it done.
In the mean time I have taken the wheels of and found the next issue. The bore of the drive wheel is flogged out due to a fair amount of abuse at some time. Whilst with the bent key and set screw in place the wheel will run true once the set screw is loosened the wheel is very wobbly. This is a problem for the tyre guy thus am going to have to get someone with more capability than me to bush the bore for me.
5th Dec 2018, 11:43 AM #20China
- Dec 2005
- South Australia
- 1,658
$50 a wheel is amazingly cheap for what needs to done, I hope the guy has done this before
5th Dec 2018, 04:16 PM #21Golden Member
- Jul 2011
- 837
https://industrial-rubber-sales-pty-ltd.business.site/
Says he has and at that price I willing to give it a go. I am pretty sure the rubber will be stuck to the wheels.
5th Dec 2018, 08:33 PM #22Most Valued Member
They do re-rubbering of castors and the like, used to work just down the street from them. They've been around for a long time, from memory I think they were BTR back then.
27th Dec 2018, 07:59 PM #23Golden Member
- Jul 2011
- 837
I picked up.my wheels last Thursday and they look to be good at first sight. I need to spin them up to see how concentric they are but when I was dropping them off they were grinding a recently rerubbered conveyor head drum.IMG_20181213_125420-3.jpg
Woodfast machine
By Turbine Builder in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 12th Feb 2018, 11:26 AM -
woodfast universal woodworker
By Turbine Builder in forum ANTIQUE AND VINTAGE MACHINERYReplies: 4Last Post: 5th Jan 2017, 06:15 PM -
SteelFast Bandsaw
By Petip in forum METALWORK GENERALReplies: 28Last Post: 18th Jun 2014, 01:43 PM -
First use of the Horizontal bandsaw! ( Or "see, I told you I needed one....")
By Sterob in forum METALWORK GENERALReplies: 2Last Post: 14th Jun 2012, 10:32 PM
