Results 1 to 8 of 8
Thread: Horizontal vs vertical milling
25th Nov 2018, 05:43 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
Just pondering .... for when I get my universal machine, When will I use horizontal ?
I know it's good for removing metal faster, but what other benefits are there ?
25th Nov 2018, 06:05 PM #2Most Valued Member
- 4,890
It will all depend on what you either have to or need to machine.
Its no use telling you what the benefits or the detriments of it will be, you will have to learn this for yourself.
25th Nov 2018, 06:05 PM #3Philomath in training
Unfortunately, the term 'universal' when applied to a mill has been corrupted these days. When you say universal, do you mean it has a horizontal spindle as well as vertical? A rotating table?
I use my horizontal for gear cutting mainly, but it does provide extra options for flexibility when setting up.
25th Nov 2018, 07:07 PM #4Senior Member
- Nov 2012
- 423
25th Nov 2018, 07:27 PM #5Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
FWIW I've had a Hafpos HM52 with 2 spindles for 10+ years and I've only used the horizontal spindle for 1 job in that time.
25th Nov 2018, 08:43 PM #6Golden Member
- Oct 2001
- ACT
- 667
have said before on the forum here that its actually surprising how many jobs can be done easily in horizontal mode - its more a choice in many cases (if your mill can do both). I leave my mill in horizontal and its the exception that I put the vertical head on.
Many mills are vertical now days and if you have the choice it can be easier/convenient to just leave it that way (vertical) -rather than 'having' to use vertical over horizontal. Some jobs though really 'need' a workpiece to be held a certain way to make it easier.
26th Nov 2018, 12:42 AM #7Golden Member
- Jul 2011
- 837
Slightly off topic, but could you use your horizontal to hob gears? it would require the table rotated to helix angle of the hob and the universal dividing head to be geared in relation to the spindle speed. You could also cut worm gears with a hob too. Or have you already done that and I havent read enough forum posts?
Eric
26th Nov 2018, 06:57 AM #8Philomath in training
Yes, you can but you need to have the gear syncronised with the spindle - a couple of large bevel gears that I haven't gotten around to making up yet... The way it would be done is a bevel gear pair to take off the spindle rotation, a universal shaft to transfer that to the dividing head location and then a gear train to connect to the dividing head input shaft. I really don't know why I haven't done it yet. Pure slackness on my part I would guess.
Some larger industrial machines even have that power take off in built.
I did hob a wormwheel on the lathe some years ago and it worked surprisingly well.
Vertical Shaper vs Horizontal
By DSEL74 in forum METALWORK GENERALReplies: 9Last Post: 2nd Aug 2022, 03:58 PM -
Horizontal versus vertical Milling
By morrisman in forum METALWORK GENERALReplies: 8Last Post: 20th Jun 2012, 06:53 PM -
Vertical Milling Head for Horizontal Mill
By seafurymike in forum METALWORK GENERALReplies: 42Last Post: 16th May 2012, 05:23 PM -
horizontal/vertical bandsaw adjustment..
By Corgan in forum METALWORK GENERALReplies: 19Last Post: 18th Aug 2011, 09:56 PM -
Horizontal/Vertical bandsaw
By Stustoys in forum METALWORK GENERALReplies: 12Last Post: 17th Jul 2010, 08:18 PM
