Results 16 to 19 of 19
24th Nov 2018, 10:13 PM #16Golden Member
- Aug 2012
- Australia
- 645
24th Nov 2018, 10:20 PM #17Most Valued Member
No, sorry. I bought it on a trip to the US. Now that Amazon has decided to ship to Oz you might be able to get it.
25th Nov 2018, 09:37 AM #18Most Valued Member
- Australia east coast
- 2,713
I've had mine since 1999 and it's not in quite as clean condition as yours but pretty close. I'm the 3rd owner; the first one built a live steam loco in his retirement. The 2nd got divorced......
There's more staining on the ways of mine from long-term storage and slathering with oil than anything else. Never been a trace of rust anywhere - I do go through quite a lot of paper towels keeping it clean though.
To be honest I don't use it a lot as I have a Colchester Chipmaster that masses 2X as much, has a lot more HP and variable speed. Plus the ergonomics are better IMO. But it's really nice having a metric lathe when I need one or can't be bothered tearing the collet chuck off the Chipmaster. I keep the Emco 4 jaw mounted on the Maximat. One day I'll fit an ER-40 collet chuck to it.
As I said I rarely use coolant - spray bottle when drilling deep holes is usually all. I use straight cutting oil when thread cutting with HSS. The rest of the time I generally use carbide insert tools dry. But keep in mind I do a lot of work with stainless and that stuff work-hardens so carbide, driven hard enough to chip-break, gives a lot better surface finish. If I was using HSS I'd have to slow down a lot and use coolant.
PDW
25th Nov 2018, 12:07 PM #19Member
- May 2012
- Tasmania
- 50
Thanks for that PDW.
I am interested to learn which oils are best to protect with but are not likely to stain or react with the paint. Im a bit anal about originality with everything and whilst I like seeing gear overhauled and repainted I value tidy original even more.
I am pumping oil through the oil nipples to flush out any grease. The saddle looks like it must include several oil ways to get all the places lubed. I am not sure if I should strip it or maybe pump kero through then oil?
I have to learn a lot about machining stainless, I recall years ago as an apprentice how tricky it can be and my first job is a coffee tamper which I will make out of SS so better get reading.
Thanks for the wonderful assistance.
Emco Compact 5 (lathe with mill)
By Michael G in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 6th Jul 2014, 08:00 PM -
Emco Maximat Wiring Diagram
By wheeler727 in forum METALWORK GENERALReplies: 0Last Post: 17th Jan 2012, 10:46 PM -
Emco unimat lathe
By vk4 in forum METALWORK GENERALReplies: 11Last Post: 16th Jan 2012, 02:28 PM -
Emco Maximat V10 Lathe
By Anorak Bob in forum METALWORK GENERALReplies: 20Last Post: 1st Oct 2011, 08:22 PM -
Emco Maximat V10-P
By SurfinNev in forum METALWORK GENERALReplies: 5Last Post: 20th Sep 2011, 06:28 PM
