Results 16 to 23 of 23
Thread: Precision Grinding Unimac
23rd Nov 2018, 10:24 AM #16Golden Member
- Dec 2007
- 574
I know of 2 of these machines, one is/was owned by a friend that I think moved to another state and I've lost contact with him and the other lives not far from me. I have used it a few times some years back before I acquired my own machinery. Like most combination machines it sounds good in theory but one needs to plan the sequence of operations involved in a project or you can find your self setting up for turning then for milling and then back for turning.
The milling cutter holders are 3M taper and have no draw bar they are held in by a nut similar to an Arboga drill/mill, the cutters are secured in the holder with a grub screw which means a flat needs to be ground on the cutter shank. The friend that moved gave me the 4 of the holders that I still occasionally use in my Arboga.
23rd Nov 2018, 05:16 PM #17Golden Member
- Jul 2011
- 837
23rd Nov 2018, 05:29 PM #18Golden Member
- Jul 2011
- 837
24th Nov 2018, 11:00 AM #19Golden Member
- Dec 2007
- 574
24th Nov 2018, 07:24 PM #20Golden Member
- Jul 2011
- 837
24th Nov 2018, 09:15 PM #21Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
I saw one of those at a auction a few years ago. Must have had every attachment and the cabinet was full of tooling. Went for about $2000. I didn’t realise they were made in Adelaide. Have precision grinding shut down yet?
26th Nov 2018, 06:52 AM #22Golden Member
- Jul 2011
- 837
29th Nov 2018, 01:04 AM #23Golden Member
- Dec 2007
- 574
Unfortunately I can't help - my mate has one of the very early examples with out the extra milling head - to use as a mill the head stock needs to be turned so it is vertical, the cutter being held in the 3 jaw chuck. I am calling around there tomorrow on another matter so I'll have a look anyway.
I can't recall how rigid it was - at the time it was early days for me as far as machining went - I was a bit hesitant to try and remove to much metal so it was light cuts only.
Precision level - or is it?
By Michael G in forum METALWORK GENERALReplies: 8Last Post: 9th Dec 2016, 06:43 AM -
practicing precision
By welder in forum METALWORK GENERALReplies: 1Last Post: 23rd Nov 2014, 05:39 PM -
SOLD: Precision level like Starrett 199
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 20th Jun 2012, 08:54 PM -
precision level?
By fubar in forum METALWORK GENERALReplies: 29Last Post: 5th Aug 2011, 08:59 AM -
Which Grinding Wheel For Grinding Tungsten Electrodes
By Metal Head in forum WELDINGReplies: 14Last Post: 8th Aug 2009, 02:23 PM
