Results 1 to 15 of 16
21st Nov 2018, 03:57 PM #1Senior Member
- Victoria, Australia
- 114
Double ended boring bars with HSS
I own one of those double ended boring bars which use HSS. Not really sure how they are suppose to be used. But guessing
- The 90-degree end is for threading Operations
- The 45-degree end is for turning operations
- Most HSS bits are ground for standard threading operations.
- Big advantage over inserts is reduced chatter. Inserts bear forces at the furthest point on the tool.
Is my understanding correct?
Thanks in advance, Tom
21st Nov 2018, 05:21 PM #2Most Valued Member
Both ends are for boring Tom. The 90 degree end is for through boring and the 45 degree end for boring blind holes (i.e. to a shoulder). You can also use the 90 degree end for cutting internal threads.
21st Nov 2018, 07:14 PM #3Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
You can also use the 45 degree end for screw cutting, you just have to grind the tool differently.
21st Nov 2018, 08:37 PM #4
I have a few of them boring bars at different sizes, I like HSS over inserts if it's not needed for hard materials.
HSS is cheap for a home shop and gives a geat finish, even on gummy material if it's ground right.
The little 1/8 HSS on small holes doesn't get much sharpening life though.
As said about you can use then either way depending on how you ground your HSS to suit threading or blind boring etc.Using Tapatalk
21st Nov 2018, 08:51 PM #5Philomath in training
If you have the grind right you can even use the 'other side' of the 45 degree end to chamfer the inside of a bored hole (if it is long enough)
21st Nov 2018, 09:22 PM #6
21st Nov 2018, 10:10 PM #7Philomath in training
No - lathe runs in the 'normal' direction. The tool is ground with a flat end, inserted so it angles back and then wound back to put a chamfer on the inside corner. Bit late for a photo tonight but if there is still confusion I'll set it up tomorrow to demonstrate.
21st Nov 2018, 10:12 PM #8Senior Member
- 114
21st Nov 2018, 10:29 PM #9Philomath in training
A picture I can do
Think of this as a section view from the top of the lathe.
21st Nov 2018, 10:41 PM #10
I see wah you mean now, reverse chamfer
Using Tapatalk
22nd Nov 2018, 03:29 AM #11
I had one given to me many years ago, its only quite recently that I have used it. Until you do you don't realise how versatile it is.Best Regards:
23rd Nov 2018, 05:28 PM #12Senior Member
- 114
Would someone be so kind and post an example of an HSS grind for this type of internal boring or provide the geometry of the HSS bit?
23rd Nov 2018, 06:02 PM #13Most Valued Member
These are screenshots of an old South Bend document on tool grinding. The doc is too big to post here unfortunately. One screenshot refers to the other.
23rd Nov 2018, 08:02 PM #14Senior Member
- 114
Interesting find http://www.cutterod.com/cutter_zone/...athe_Tools.pdf
23rd Nov 2018, 08:20 PM #15Most Valued Member
Yep, that's the same document.
Double-ended Morse Tapers
By electrosteam in forum METALWORK GENERALReplies: 13Last Post: 20th Dec 2016, 09:24 AM -
Macson Double Ended Grinder
By camoz in forum METALWORK GENERALReplies: 22Last Post: 8th Oct 2013, 09:29 AM -
Double ended No. 1 Morse Taper
By Alby123 in forum METALWORK GENERALReplies: 8Last Post: 15th Sep 2012, 01:10 AM -
what are these boring bars used for
By azzrock in forum METALWORK GENERALReplies: 5Last Post: 31st Aug 2011, 07:47 PM -
Boring bars
By Bodgy in forum METALWORK GENERALReplies: 6Last Post: 29th Jun 2008, 12:32 PM
