Results 1 to 1 of 1
19th Nov 2018, 11:41 AM #1Golden Member
- Dec 2007
- 574
Taiwan belt driven lathe gear/thread calculator
I have one of these belt driven Taiwan made lathes
Taiwanese Lathes by Brazier's Lantaine, Enco, Wey II Corp, Warco, Peerless, Kin Shin, carolina with Models: 1122, 1124, 1224, 1236, 1340 & 1327 Lathes
- sold under many different logos/brands. The range of threads that are able to be cut as shown on the threading tables is quite good but there always comes that one time that a thread comes along that is not listed in the supplied tables. The attached Excel file may be of some use to some members.
In my case the plastic CO2 gas cartridge holder on my soda syphon had split so I could no longer charge it up - I set about machining up an aluminium replacement and I wanted a 1.75mm pitch thread which is very close to 14.5 TPI neither of these is listed on the supplied tables, an hour or so spent with Excel and I came up with this handy calculator, I played around with various combinations of gears that came with the lathe and settled on a combination that while not exact did give a very low error of .0045mm per turn. It all worked fine and I'm recharging my soda syphon again
My lathe has an 8TPI lead screw and was supplied with the usual 120/127 metric translation gears plus 2x40 1x46 1x32 and 1x30 tooth gears, to use the spread sheet simply enter combinations of the gears you have into the cells shaded in green, (don't forget to press enter) and look through the tables to find the closest match possible - the 2nd and 3rd gears will always be either 120 or 127 teeth.
A word of warning, none of the cells are protected or locked so it is possible to alter the contents of any cell and screw up the calculations so best thing is to stick to the green shaded cells only.
Belt Driven Drill Press
By John T K in forum ANTIQUE AND VINTAGE MACHINERYReplies: 4Last Post: 5th Oct 2017, 12:06 PM -
Small Benchtop Belt Driven Lathe - Valuation Sought'.
By neildawes in forum METALWORK GENERALReplies: 9Last Post: 19th Apr 2016, 01:04 AM -
Lathe thread cutting change gear calculator
By Vernonv in forum METALWORK GENERALReplies: 61Last Post: 20th Dec 2015, 08:38 AM -
Belt Driven Working Metal Workshop
By DSEL74 in forum METALWORK GENERALReplies: 6Last Post: 8th Oct 2014, 09:57 AM -
Treadmill donkey on a Nuttall belt driven spindle?
By fuglee1 in forum METALWORK GENERALReplies: 2Last Post: 28th Dec 2013, 04:50 AM
