Results 16 to 18 of 18
Thread: Quick change tool post advice
20th Nov 2018, 12:43 PM #16Most Valued Member
- 4,890
The tool post is the only physical difference, the only trouble you may encounter between the two may occur if you buy additional tool holders, as I mentioned earlier some times additional tool holders may not seat correctly on the wedge type without a little bit of fiddling with the dovetail.
20th Nov 2018, 12:47 PM #17
I have never seen them advertised differently, so they would be the same.
I have read about some being to tight of a fit or loose, or the handle indexing in a different position because there slightly different.
Some guys have bought a batch from CDCO and find one or 2 are tight or loose, I don't think there is any great quality control considering them being so cheap.Using Tapatalk
20th Nov 2018, 03:23 PM #18Diamond Member
- Aug 2006
- 1,106
Yeah I noticed with some of mine they are not as tight as I would like them to be, so I just place a bit of shim stock between the piston and the tool holder. Seems to do the trick.
I need some more holders, just waiting for them to come up at a bargain price, there was some listed on banggood last year at $15 each, the next day when I went to purchase they had gone back up to over $20 or if I get some suitable stock might just attempt to make a bunch
Advice on a quick change tool post for a Hercus 9" ( a gift so I cannot check the fit
By Ben Dono in forum METALWORK GENERALReplies: 3Last Post: 15th Dec 2014, 07:45 PM -
By TKO in forum METALWORK GENERALReplies: 5Last Post: 20th Oct 2013, 10:15 PM -
quick change tool post help
By Aerohydro in forum METALWORK GENERALReplies: 5Last Post: 23rd Apr 2012, 12:11 AM -
By scratchbuilt in forum METALWORK GENERALReplies: 18Last Post: 13th Mar 2012, 07:46 PM -
Quick Change Tool Post
By tinkera in forum METALWORK GENERALReplies: 3Last Post: 22nd Sep 2010, 11:17 AM
