Results 1 to 15 of 15
16th Nov 2018, 08:44 PM #1.
- 6,459
Tough Drill Intermediate Pulley Question.
I'm in the process of replacing my Tough drill's intermediate pulley support components with new parts made from 316 due to their exposed location.
There is evidence that someone has been inside the pulley previously and evidence aplenty elsewhere that they didn't really know what they were doing. The slots worn in the belt guard are an indicator.
I'm wondering if anyone has a Tough with an intermediate pulley whether they could either photograph or describe what is between the circlip and the pulley? I don't imagine that it is a pair of ill fitting washers. It is possibly a dust cover that bears upon the inner race of the bearing and is retained by the circlip.
Bob.
IMG_20181017_153021426 (Large).jpg IMG_20181017_145817628 (Large).jpg IMG_20181017_153703821 (Large).jpg IMG_20181116_160206298 (Large).jpg IMG_20181116_160216953 (Large).jpg IMG_20181116_160624325 (Large).jpg
17th Nov 2018, 06:33 PM #2Senior Member
- Apr 2014
- 134
bob
mine has just got the circlip no washers but is a very neat fit on the shaft
maybe its to take up a little bit of wear
steve
17th Nov 2018, 10:55 PM #3
This is my unmolested one , it's hard to see under the dust but it is just a circlip as well
( I took the photos up the right way )
Rick
18th Nov 2018, 09:49 AM #4.
- 6,459
Thanks for the replies Steve and Rick and for the photos Rick.
In the Tough drill's evolution things have changed. The cast aluminium belt guard probably predates the cheaper pressed metal guards fitted to my Tough. The through hole in the top of my intermediate pulley is 7/8" and the vertical shaft or spindle measures 17mm below the 5/8" UNF threaded section. The earlier versions of the drill appear to have a hole with less clearance in the pulley and the circlip's role could be simply one of a dust cover.
Here is Node105's Tough morticer's pulley -
A small variation in the pulley's shape but a close fitting bore. Something I find strange is that Tough provided the lower bearing's threaded retention ring with a felt seal and, what appears so far, nothing more than a circlip to protect the upper bearing ??
When I made the replacement for the screwed retaining ring I abandoned the felt seal. I will install sealed 6203 bearings in the pulley.
Bob.
18th Nov 2018, 05:46 PM #5Intermediate Member
- Aug 2000
- 34
Hi Bob
Would it be too much trouble to ask if you have any sketches or drawings of the components you are going to remake?
I have two Tough drill presses both 4 speeds one quite old with MT2 spindle the early partial belt guard and a later Jacobs take version with the cast guard. Adding an intermediate pulley to one of them looks like a good project once I get my lathe running. Are you also able to give me the dimension for the intermediate pulley shaft in relation to the two motor mounting shafts please?
Regarding the Tough drills evolution, it's almost like they were constantly changing them. I see yours and a few others on the net don't have the stiffening rib like this one does I found on an old woodwork forums post but you have the pressed belt guard not the cast one.
Woodwork Forums
Even though my motor mounts don't have the intermediate mounting, the castings where the shafts mount on my one with the cast guard are a lot more substantial than any others I've seen. It's such a pity they rust so badly! I think it's because we don't use them and they sit for most of the time. I got mine from my father when he retired and never remember them rusting that much when he used them in his business. But I guess back then there was always someone using them and they had oily hands allover them.
18th Nov 2018, 08:40 PM #6.
- 6,459
Darryn,
For some weird reason I have an aversion to drawing these days. Could well just be laziness. So how about this as an alternative. You can have the parts I've made replacements for.
If you are prepared to pick the parts up you can measure the intermediate pulley bracket. I'm 6 km NE of Perth CBD. Send me a PM if you are interested.
Tough changed the centre distance between the motor support rails. I thought that I could simply slide the intermediate pulley bracket onto the rails of my now gone earlier 4 speed. I couldn't. As you say, constant changes.
Bob.
IMG_20181031_153229483_HDR (Large).jpg IMG_20181031_153517446 (Large).jpg IMG_20181116_161404397 (Large).jpg
19th Nov 2018, 09:26 PM #7Intermediate Member
- Aug 2000
- 34
Thanks very much Bob
20th Nov 2018, 04:31 PM #8Senior Member
- Perth, Western Australia
- 67
- 362
Tough drills must be a thing in WA.
https://www.gumtree.com.au/s-ad/rock...ill/1201327237
20th Nov 2018, 05:20 PM #9.
- 6,459
They were made in the Perth suburb of Belmont. Some of them made it across the border!
20th Nov 2018, 11:46 PM #10Most Valued Member
- Oct 2007
- 3,112
21st Nov 2018, 02:54 AM #11Senior Member
- 67
- 362
21st Nov 2018, 02:56 AM #12Senior Member
- 67
- 362
24th Nov 2018, 09:59 PM #13Most Valued Member
- Charlestown NSW
- 1,673
This probably should be classed as "interesting but not directly related to Bobs original question" However, My late uncle had a Tough pedestal drill, it had made it all the way to Newcastle in NSW.
Anyway after my uncle died my aunt asked me to help her sell most of his gear. This was in 2016. So I worked my way through his shed and eventually sold the Tough DP on ebay.
The buyer turned out to a relation (I think the grandson) of the person whose factory made the machines and whose name is on them.
The buyers last name was Tough as well.
Small world.
peter
24th Nov 2018, 11:27 PM #14Most Valued Member
25th Nov 2018, 12:05 AM #15Senior Member
- 67
- 362
It seams I am noticing these things more since this thread started. Another gumtree quality unit.
https://www.gumtree.com.au/s-ad/west...ion/1201770597
Tough Drill, Tough Sale
By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKETReplies: 6Last Post: 27th Sep 2018, 08:26 PM -
Waldown Intermediate Pulley Eccentric Mount Photos
By Anorak Bob in forum METALWORK GENERALReplies: 20Last Post: 23rd Apr 2015, 06:57 PM -
Tough Drill spare parts
By krisfarm in forum METALWORK GENERALReplies: 11Last Post: 30th Jan 2015, 07:50 AM -
Tough drill press
By node105 in forum METALWORK GENERALReplies: 17Last Post: 5th Jun 2013, 05:06 AM -
Tough Drill Press (gloat)
By Bryan in forum METALWORK GENERALReplies: 49Last Post: 1st Sep 2011, 12:06 AM
