Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Oct 2018
    Sydney
    27
    Quote Originally Posted by TomW View Post
    Hi kyp
    This isnt the complete manual but may have something useful for you
    Hope to find original one day .
    Cheers tom
    Tapatalk Cloud - Downlaoad File 3419_001.pdf
    Sent from my SM-G965F using Tapatalk
    Hi Tom,
    Sorry to be a pain but you seem to be the only person on the internet with HAMATU manual, any luck finding it?
    Chrs,
    Ryan
  2. #17
    Jul 2009
    perth
    67
    Sorry Ryan
    I have had a good search with no success.....
    I think my original manual may have accidentaly got binned
    Tom
  3. #18
    Oct 2018
    Sydney
    27
    Sorry Ryan
    Tom
    Thanks for trying
  4. #19
    Oct 2018
    Sydney
    27
    Hey Guys, does anybody know how change gears are spec'ed on HAMATU lathe?
    Is it mod 1 or something? I'm missing some gears for imperial thread cutting.
    I also have weird issue with metric thread cutting. When I setup the lathe for 1.25 pitch it actually outputs 19g which is close but not close enough to put a nut on.
    Where should I look to pin point this behavior?
    Hope somebody can help.
  5. #20
    Jan 2019
    crossley VIC
    81
    10
    Default hammatu lathe
    Hi KYP,
    you don't say whether your lead screw is metric or imperial. Mine is imperial ,4TPI and the gear train to cut imperial threads are:upper gear48,driving 127 which drives 71 which drives 38 on the lowest gear. Probably the gearbox input shaft.I haven't mastered the art of posting photos from my phone to this blog yet .When I do Iwill post photos of my lathe
    Cheers Walter Mitty
  6. #21
    Jan 2019
    crossley VIC
    81
    10
    Default gear train
    Hi KYP,my gear train which in conjunction with a 4 TPI leadscrew is:48Tdriving127T which drives38T which is mounted on the lowest shaft .Seems to be the feed gearbox shaft.
    Cheers Walter Mitty
  7. #22
    Jan 2019
    crossley VIC
    81
    10
    Default corrections to previous reply
    Apologies KYP train is 48 driving 127 driving 71 driving38
    Cheers Walter
  8. #23
    Oct 2018
    Sydney
    27
    so, it is 4tpi lead screw. and according to the chart it is 48->127-105->84 gear box setup for metric threads. The lever position on the chart shows No.4 for 1.25mm pitch but in that position the thread is off. I have found it works to a spec if I move lever to # on the chart - 1 so 3. Same for 1.5mm pitch it is 5 instead of 6. It doesn't look like the access to the lead screw gearbox is easy. I wonder what can be wrong. I really like the lathe and want it to work by the book.
  9. #24
    Jul 2016
    35
    1,522
    Maybe pop up a photo of your geartrain and the manual page?
  10. #25
    Jan 2019
    crossley VIC
    81
    10
    Default hamatu lathe
    Hi KYP,looking at the chart on the lathe,to cut a metric 1.25 thread,set the machine on: 1 which is the gear train you mentioned: 4.
    You never mentioned Lever 1 or Lever C.
    Cheers Walter Mitty
  11. #26
    Oct 2018
    Sydney
    27
    Quote Originally Posted by Walter Mitty View Post
    Cheers Walter Mitty
    Those are also set as per chart. The Lever position is the only difference.
  12. #27
    Jan 2019
    crossley VIC
    81
    10
    Quote Originally Posted by kyp View Post
    maybe engage half nuts,set up dial indicator and turn lathe by hand 1 revolution and measure travel.Compare to chart on lathe and see where you are.
  1. Hamatu lathe electrical issue need help
    By Lupa338 in forum ELECTRICALS
    Last Post: 16th Jan 2018, 08:16 PM
  2. Hamatu Lathe on Single Phase
    By GuzziJohn in forum METALWORK GENERAL
    Last Post: 18th Apr 2013, 09:24 AM
  3. Hamatu Lathe
    By GSRocket in forum METALWORK GENERAL
    Last Post: 17th Nov 2012, 10:40 AM
  4. Hamatu 20
    By Nrbar in forum METALWORK GENERAL
    Last Post: 17th Oct 2012, 10:34 PM
  5. Hamatu Lathe
    Last Post: 24th Jun 2012, 12:45 PM
