Results 1 to 12 of 12
Thread: Need a lathe
    Nov 2018
    perth
    68
    8
    Default Need a lathe
    Hi all
    My qc6125 lathe not worth preparing or molding will put money towards a new replacement
    What can people tell me what they think of
    TU2506v optimum
    Or
    Similar size
    AL series
    From
    Hare and Forbes
    Both available here in Perth WA
    Many thanks
    Keiron
    Apr 2013
    Toowoomba Qld
    401
    I think the general consensus is they are too small to do any real work but if you have no other alternative then with enough patience you can do some work with them.
    Are you looking at that size due to weight / size restrictions or budget ?
    What kind of work are you planning to do with it ?
    6,481
    Hi Keiron,
    Quote Originally Posted by Noriek View Post
    Hi all
    TU2506v optimum
    Or
    Similar size
    AL series
    From
    Hare and Forbes
    Many thanks
    Keiron
    That QC6125 is slightly bigger than my Myford ! I’m curious as to what makes it not worth repairing.
    Nov 2018
    perth
    68
    8
    Hi
    Thank you for reply
    Firstly
    Need a drive belt that goes between the motor and pully
    I have spent days scouring the internet and also with pulleys and such in hand visited local supplies who have said not available due to an unavailable pitch.
    The original belt disintegrated.
    I was then thinking of molding the lathe with a bad and three phase but I then need a belt to drive the pully set even then I will need something other than the original.
    Secondly
    Space
    Dimensions of where the lathe will fit
    Home 5m x 5 m garage with fixed benches and such limited in size lathe. Nice to go a bit bigger
    The original qc6125 fitted nicely
    Am aware lot of the small stuff is of a similar likeness. Still deciding
    All best
    Nov 2018
    perth
    68
    8
    Sorry typos due to predictive text
    Molding = nodding
    Bad = VFD
    Apr 2013
    Toowoomba Qld
    401
    What pulleys / What pitch ?
    is there enough meat on them to recut them for a standard available belt ?
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by MasterSpoon View Post
    Exactly..or get new pulleys?
    but any belt that is close should do...go to Consolidated Bearings (CBC) or the like
    Nov 2018
    perth
    68
    8
    Hi went to local machine shop for quote
    Expensive
    Re pelt pitch as said went to a couple of belt suppliers
    We were on the same page
    If pitch not Spot on belt will soon be damaged
    6,481
    Hi Keiron,
    Toothed belts are not expensive at all ! I find it hard to believe that you can't find or get one, if not locally then via the many places on the Internet.
    I needed a toothed belt recently and this company "www.bearingboys.co.uk" bent over backwards to assist me in getting the right toothed belt. It only cost £3.55p UK. Made by "Dunlop". I would go and have a look at their web site. I also got a matching pulley from them, also made by "Dunlop".
    Disclaimer: No connection, just a satisfied customer.
    Aug 2011
    Perth, Western Australia
    67
    362
    Have you tried Transeals in Kewdale ?
    They have had everything I have ever needed.
    Nov 2018
    perth
    68
    8
    hi there Baron J and BJS
    thanks for tips, will follow up
    also looking at getting rear of pully perhaps remachined and replace the driving pully on the motor. The pully set is a set of three v, s with timing belt splines machined on rear. the pully on the motor shaft is only 28mm diameter, too small for other than a timing belt drive.
    will see what comes up.
    If able to get the timing teeth recut will go for 5mm pitch, and will have to work out new appropriate diameter and suitable length belt. I believe there are calculators on line
    regards
    6,481
    Hi Keiron,
    Post some pictures of the pulley arrangement and maybe a measurement of the tooth width and spacing.
    The "V" belt should be quite straightforward to find.
    As far as recutting the teeth, there are quite a number of variations in tooth width and spacings. 5.08 mm just happens to be the one that was correct for my machine. Indeed the motor shaft pulley on my machine is only 25.5 mm OD.
  1. Replies: 2
    Last Post: 15th Jul 2013, 01:24 AM
  2. Any Atlas Lathe and Drummond Lathe Owners out there?
    By j.ashburn in forum METALWORK GENERAL
    Last Post: 8th Apr 2013, 06:22 PM
  3. SOLD: Lathe for Lathe Drill Mill (Near Liverpool NSW)
    By Auskart in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Jun 2010, 07:02 PM
  4. Buying a lathe (Old massive Lathe, or New small C6 Lathe)
    By Ch4iS in forum METALWORK GENERAL
    Last Post: 25th Mar 2009, 12:19 PM
