Results 16 to 30 of 44
  1. #16
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    The same kind of springs are used in vacuum cleaners to return the powercord into their cubby hole, as well as starter cord returns on chainsaws and motor mowers.
    They are sold on eBay, Alibaba and Aliexpress in any size you can imagine - as mentioned before, they are all less than $10, often delivered. That was the source for my missing 8SN and the broken one in my Servian drill press....
    Cheers, Joe
  2. #17
    6,473
    Thumbs up
    Quote Originally Posted by lamestllama View Post
    BaronJ
    20mm definitely won't fit but thanks for the photos. Along with Petips post it gives me some impetus to search on ebay.
    Eric
    Hi Eric,
    When you quoted the width in your earlier post I suspected it wouldn't fit. The Fobco one is 16 mm wide as well. The replacement I got came from the bay. But I paid quite a bit more than $10 for it, about double if I recall. But it was free postage.
  3. #18
    Jul 2011
    Adelaide
    837
    I just had an quote from Brobo at $76 + $18 Freight + GST So I am motivated to find an alternative.
  4. #19
    Jul 2006
    Athelstone, SA 5076
    4,258
    Eskimo,
    I only have 4 Waldowns with only the 2 NH's able to do useful work. You mentioned your collection was at least 5 a short while ago, now you have moved on an NH we might possibly be equally greedy?
    Eric
    only 4 eh....me too now, yep, got rid of one to Michael G...all have been now fixed up so they cant breed...although there there is an auction today with one it...lol
  5. #20
    Nov 2008
    Perth WA
    6,459
    Eric,
    The 3M quill is more substantial than that fitted to an 8SN and the return spring fitted may well be stronger. The replacement genuine Waldown spring I have on my 3M is 5/8" wide and approximately 1mm thick. I'm not unfurling it to tell you how long it is!!!!
    IMG_20181113_065249102 (Large).jpg IMG_20181113_063921098 (Large).jpg IMG_20181113_064059362 (Large).jpg
    Bob.
  6. #21
    Jul 2011
    Adelaide
    837
    It would genuinely be an addiction if one were to bid on the 8SN at the hospital.
  7. #22
    Jul 2011
    Adelaide
    837
    Eric,
    Bob.
    Bob
    I have the original spring and am wondering about a repair. At over $100 for a new one it seems worth a try. As you can see in this photo IMG_20181113_170027.jpg only the very end of the spring is broken. My thoughts are to try annealing just the end of the spring and rebending it (I don't have an oxy set so this is easier said than done) or maybe use a dremel to make a couple of holes through the spring and rivet something on. Any thoughts as to the relative chances of success?
    Eric
  8. #23
    Aug 2006
    1,106
    Yeah i'd attempt to repair that, pretty sure I have done a similar thing in the past. I don't think I applied any heat to it, just bent it to suit.
  9. #24
    Nov 2008
    Perth WA
    6,459
    Eric,
    It is weird that the spring hasn't unfurled itself. Hopefully it still has enough tension when wound up tighter to do the job if you can actually bend the end of the thing back to usefulness.
    Bob.
  10. #25
    Jul 2011
    Adelaide
    837
    I lost it by $5 due to being given dinner at precisely the wrong moment. I wanted the motor pulley (its only 4 speed) as an interim solution for my 8SN but Anorak Bob has just sold me one so until I can find the parts to make it 8 speed I will have something to make holes with.
  11. #26
    Jul 2011
    Adelaide
    837
    Eric,
    Bob.
    Any suggestions on bending it?
  12. #27
    Oct 2004
    Southern Highlands NSW
    1,898
    Bob
    Eric
    An alternative to heat the end of the spring:
    https://www.ebay.com.au/itm/1000W-ZV...frcectupt=true
  13. #28
    Apr 2012
    Healesville
    2,129
    Just clean/square up the end with a grinder and dress the corners, then if you can find a way heat it up to red/orange you just twist a new bend on there with a pair or pointy nosed pliers and let it cool in the air.
    shed
  14. #29
    Jul 2011
    Adelaide
    837
    IMG_20181113_202237.jpgWhile you were crafting that advice I did pretty much that. It is just left to see how long it lasts for. Here it is installed for a test. The whole needs to come apart. Whatever grease was used on this machine seems to have turned into tar.
  15. #30
    Jul 2006
    Athelstone, SA 5076
    4,258
    I resisted...could let you guys think I had a problem
  1. Waldown at 170 hz
    Last Post: 27th Oct 2015, 08:06 AM
  2. What to do with an old Waldown 8SN
    By camoz in forum METALWORK GENERAL
    Last Post: 2nd Jun 2013, 03:41 PM
  3. Waldown ..... again
    Last Post: 14th May 2012, 11:32 AM
  4. RFQ: Lathe Work And Mill Work
    By twistedfuse in forum METALWORK GENERAL
    Last Post: 18th Jan 2012, 04:23 PM
  5. Another Waldown
    Last Post: 17th Sep 2011, 12:06 AM
