Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Nov 2012
    Mid North Coast NSW
    203
    I've been searching for the last 3 weeks but No hadn't thought of that at all.
    That's an excellent pick up especially the manuals link. Thanks. Wish I could read it but then the pictures will help I'm sure.
    I guess if I keep looking maybe one of these Russian ones will have English in it.
  2. #17
    Nov 2012
    Mid North Coast NSW
    203
    So how does table rapids work ?
  3. #18
    Apr 2012
    Healesville
    1,137
    Quote Originally Posted by phaser View Post
    open the link below then copy and paste the webpage link into the box and push the translate button
    Google Translate Web - iTools
    shed
  4. #19
    near Rockhampton
    5,741
    Engage feed, push rapid button, I have an eastern bloc milling machine as well and it uses an internal 24V electric clutch to make the rapids work. The clutch coil was burnt out (ex tafe machine) when I got the machine and had to get it rewound,
  5. #20
    Nov 2012
    Mid North Coast NSW
    203
    So does that electric clutch engage a different set of gears or something ?
    Is this what that electric clutch looked like ?
  6. #21
    near Rockhampton
    5,741
    Mine is a totally different mill so looks nothing like that. But the clutch just has an overrunning clutch attached to it, so when it engages is overrides any existing feed and rapids along.
    To test the coil just check for resistance. Infinite resistance means the coil is burnt out. If the coil is good, check it is getting electricity when you press the rapid button.
    I think the power flows through the box like I have put the lines in the photo, green is normal feed, and the light blue is rapid flow. Not shown in the photo I suspect there would be a gear on the shaft near the clutch that engages that big output gear?
    The USSR stuff is pretty simplistic mechanical wise, but they had over complicated electrics. that will not help matters.
    You can read about the adventures I had with mine here -->> Jafo milll repair
  7. #22
    Nov 2012
    Mid North Coast NSW
    203
    Great pic.
    Thanks that helps me understand a lot.
    and yes there are other gears inside that will mesh when the box is replaced.
    One thing I forgot to say. When the feed motor is running and you hit the rapids button the motor wants to stall. Now that I realize about these clutches, esp the one way clutch, I suspect the motor could be running backwards.
  8. #23
    Nov 2012
    Mid North Coast NSW
    203
    .RC. In my last photo showing inside the box, the motor (lower right) outputs to the shaft ending with the gears at the back (left side). So that means your overlay of my gearbox will be correct but back to front. In other words just reverse all the arrows you drew.
  9. #24
    near Rockhampton
    5,741
    Yea that does not surprise me as it makes more sense for the power to flow that way as then only the output shaft speeds up, I just was not sure of the gear that drives the rapids clutch.
  10. #25
    Nov 2012
    Mid North Coast NSW
    203
    Neither did I until I studied the photos for the 47th time and it suddenly dawned on me.
  1. Russian milling machine
    By phaser in forum METALWORK GENERAL
    Last Post: 2nd Nov 2018, 12:57 PM
  2. Milling Machine
    By CAC221 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 6th Feb 2018, 12:57 PM
  3. Milling machine set ups.
    By 4-6-4 in forum METALWORK GENERAL
    Last Post: 1st May 2012, 03:04 PM
  4. Milling machine
    By lamestllama in forum METALWORK GENERAL
    Last Post: 25th Apr 2012, 01:30 AM
  5. HM 50 milling machine
    By woodfast in forum METALWORK GENERAL
    Last Post: 19th Apr 2012, 07:12 PM
