Results 16 to 25 of 25
Thread: Chainsawing dirty wood
29th Oct 2018, 02:47 PM #16Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Thanks for the picture, looks like you were pretty cramped in there.
bob
29th Oct 2018, 04:01 PM #17Senior Member
- gold coast
- 303
And I doubt I could have blown it out--even if I still had my shotfirers licence.
They certainly seem to be a thing of the past these days!!
29th Oct 2018, 04:41 PM #18Most Valued Member
- Healesville
- 2,129
If you could bothered you could make a root saw.
They fit in the same place as the bucket, a little machine like that you could get away with 4" x 1" x 2ft long, cut teeth into it and put a 45 on the end so it pushes into the ground easier.
You poke it in at a root and pull it into the root and draw it out at the same time, repeat until you cut through, might take a few goes on the larger roots.
If you have hydraulics then why not use them.
Cheers, shed
29th Oct 2018, 04:59 PM #19Most Valued Member
- Oct 2007
- 3,112
So that's basically a ripper with teeth on it?
The two attachments I would like to have would be a thumb and a ripper, both are not exactly rocket science to make, but it's all a matter of time. It wouldn't be at all difficult to incorporate teeth and even harden them if required.
The chances are I'll be finished all the work with it and sell it on before I'd get them made. I won't take this excavator with me when I move, and as it will be on to land I'll be aiming for a bigger excavator. This one is great as I can get it in to tight spots (as it is now, it's now working over the top of where that stump was), and it can be towed with a conventional ute etc. Unless I had some special need for something bigger the next one will probably be around the 3 tonne mark. A good size, still small enough to tow with a normal truck, but can move a fair amount of soil. Even this one will move a surprising amount of dirt around.
Yes I agree, hydraulics are king. I've seen all manner of attachments for excavators, including some giant scissor things that chomp through logs and roots. Very cool.
29th Oct 2018, 05:16 PM #20Most Valued Member
- Healesville
- 2,129
The one I used didn't have the ripper on it but I like the idea as it could stop a bit of jarring by stopping you from slipping over the top of the root.
here is one root_ripper
29th Oct 2018, 05:29 PM #21Diamond Member
- Jun 2010
- Canberra
- 1,322
I just finished removing this lump of joy the other week.
Access was only enough to get a Dingo in, which did OK at ripping up some of the small roots, but as you can see, most of the roots were easily 6" and bigger.
Used a chainsaw where I was reasonably confident of not hitting dirt, and a reciprocating saw where I was cutting in dirt. I got quite adept at sharpening those blades with the cut-off wheel in a dremel.
Had some luck making vertical cuts and pounding in a steel wedge.
Once I got tired of sharpening chains and blades, and more importantly, I'd sighted the 1/2" natural gas line that runs nice and shallow directly under the stump, I hired Kennards' new 30hp tracked stump grinder, which proved to be quite an effective machine.
29th Oct 2018, 05:32 PM #22Most Valued Member
- Oct 2007
- 3,112
29th Oct 2018, 11:28 PM #23Most Valued Member
- Healesville
- 2,129
If you are thinking of moving to a larger property and getting a bigger excavator then i guess that you orta think about
upgrading that piddly little c/saw, some contenders here https://www.youtube.com/watch?v=j8WK9wKOL4I
30th Oct 2018, 09:31 AM #24Pink 10EE owner
- 6,218
I dunno Pete, where was your sense of adventure. Here is the obvious answer
And there is always the option of shooting the roots off.Gold, the colour of choice for the discerning person.
30th Oct 2018, 10:07 AM #25Most Valued Member
- 4,258
Metal-working is not a dirty word
By ChoppaT in forum METALWORK GENERALReplies: 3Last Post: 4th Apr 2009, 02:59 PM
