Results 46 to 60 of 63
Thread: Thinking about milling machines
26th Oct 2018, 11:04 AM #46Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
Pretty sure the one I'm looking at now is 40 taper.
And it's 3KW / 4HP.
26th Oct 2018, 11:45 AM #47Senior Member
- Nov 2012
- 423
Hi Dave J....You need to clear your stored private messages
26th Oct 2018, 01:12 PM #48
26th Oct 2018, 01:16 PM #49Senior Member
- Nov 2012
- 423
28th Oct 2018, 08:11 PM #50Senior Member
- Nov 2012
- 423
The cost for moving it say 6 Klms isn't as bad as I thought.
Still not cheap at around $400 but it's reasonable considering the trouble they have to go to.
That's with a local crane mob.
28th Oct 2018, 08:24 PM #51Most Valued Member
- Jul 2016
- 35
- 1,522
Up in your neck of the woods finding a decent mill probably isn't that easy, I'd get on it and move it. I have moved machines about 6 times this year it gets easier and cheaper each time.
28th Oct 2018, 08:26 PM #52Most Valued Member
- Jul 2016
- 35
- 1,522
But also I'm a bad influence and a bit tipsy in a bar, don't listen to that advice.
28th Oct 2018, 08:50 PM #53Senior Member
- Nov 2012
- 423
28th Oct 2018, 08:54 PM #54Senior Member
- Nov 2012
- 423
One other thing I'm a bit worried about, is, making sure all the parts are there. In other words, is there any special spanners, gears, or any sort of parts that the machine needs that if they're missing would stop full use of the machine ?
28th Oct 2018, 09:11 PM #55Most Valued Member
Find out if anyone is close to you that could come and have a look to help you make sure that everything is there.
28th Oct 2018, 09:18 PM #56Most Valued Member
When I bought my mill (bridgeport clone) I had no real way of knowing if all the parts were present. The The variable speed head was disassembled and in a million bits in a box. I made a judgement as best I could as to what may be missing and took a calculated guess that I would be able to make or source any missing parts. I had never owned a mill like this before so it was all foreign to me. But for $1200 I got the mill, a sony DRO, 8" spacer block and a universal dividing head so I figured I would at least get my money back if I made a bad decision.
In the end I think I got lucky. The parts that were missing were few and easy to make but it was obvious from the minute I saw it that it was not going to be a take home and instantly use type machine. Much work was needed but it was work I was willing and able to do.
If the price is right and the mill looks "OK" then gather as much info as possible. If it still looks like a good deal, then grab it. If it has parts like gears etc. missing then they can be made if need be.
Kryn makes a good suggestion too.
28th Oct 2018, 09:26 PM #57
Spanners can be made, change gears are unusual for a milling machine, that's more lathes. It will be more like what tooling comes with it and does everything run. As I said in pm with it's few problems, go in with a low offer he can only go up.
Using Tapatalk
29th Oct 2018, 11:13 AM #58Senior Member
- Nov 2012
- 423
29th Oct 2018, 01:00 PM #59Most Valued Member
- Australia east coast
- 2,713
Yeah, maybe. Try that with me and I'd just say no. Make a really low offer on a working machine and I most likely wouldn't even respond to you at all if I'd priced it to sell reasonably quickly already. Gumtree is generally the refuge of bottom feeders which is fine, but there are limits.
PDW
29th Oct 2018, 01:30 PM #60
CNC vs manual milling machines
By Pumpkinate in forum METALWORK GENERALReplies: 31Last Post: 23rd Sep 2019, 10:52 PM -
Mid 1900's milling machines?
By country kid in forum METALWORK GENERALReplies: 8Last Post: 26th Jun 2016, 02:58 AM -
New Milling machines - which/where
By gmetal in forum METALWORK GENERALReplies: 23Last Post: 23rd Jun 2015, 08:59 AM -
Bridgeport milling machines
By morrisman in forum METALWORK GENERALReplies: 8Last Post: 22nd Dec 2013, 05:22 PM -
Milling Machines in Perth
By Sterob in forum METALWORK GENERALReplies: 5Last Post: 29th Sep 2006, 11:03 PM
