Results 1 to 8 of 8
Thread: Help with tailstock
16th Oct 2018, 06:43 PM #1Senior Member
- gold coast
- 303
Help with tailstock
Hi everyone.
I really need a bit of advice and help please.
I have a AL250G lathe and for some ungodly reason I pulled on the inner shaft when it was almost extended and pulled it out of the body. Please dont ask me how or why I did this.
The problem now is I cant get it back.
I can slide it into the body but I cant get the threaded rod to engage to pull it back inside, when I reverse the adjustment wheel
I also notice theres a small keyway along the underside and I have no idea if anything should engage there to stop the shaft from rotating. (Im guessing there should be something).
I've messed around with it on the bench for half an hour with no success, and Im hoping theres a sequence of steps I dont know about.
I'm open to any advice or help please
regards
Brin
16th Oct 2018, 07:07 PM #2
Not familiar with your lathe, but it sounds like the key has dropped out.
Take it off the lathe completely, find the key and resemble it, a dob of grease to hold it in position if it tries jumping outUsing Tapatalk
16th Oct 2018, 07:10 PM #3Philomath in training
- 6,541
Don't panic Brin (Brian!) it will go back together as that is the way they are built.
16th Oct 2018, 08:49 PM #4
Hi Brian,
My lathe does this nasty little trick on occasion. It's not a biggy.
I think you may find the key located at 6 ock and 25mm or so back from the front edge.
That's if-if the generics of our lathes are similar.
If so, its just a matter of making sure the key is level/horizontal-not cocked high, one end or the other.
The trick is to engage the external keyway in the threaded tube to the key by working the tube slightly one side to the other in a twisting motion and applying light pressure.
My money is on the key not being level.
17th Oct 2018, 11:28 AM #5Senior Member
- Jul 2008
- Sydney Australia
- 142
Remember too, it's a left-hand thread. CCW to re-engage !
20th Oct 2018, 09:40 AM #6Senior Member
- gold coast
- 303
Thank you all for your thoughtful and helpful advice.
I took the tailstock off and set it up in the vice where i caould see it properly.
As you suggested theres a key inside the bore.
HOWEVER being a chinese lathe it took several tries before I realised the key was not the sort of thing I was used to and in fact had a little spindle on the underside that slipped into a little drilled hole. This means the key can turn any which way, and does so as soon as the spindle of the tailshadt touches it.
so it took some stoning and care before I could get it to engage in the keyway.
Once that was done the rest was easy.
My thanks agai for all the help
warm regards
Brian
20th Oct 2018, 06:58 PM #7
The quill anti rotation key on the Optimum mill is like that ! A rectangular strip with a little spigot that sits in a hole. Cheap but effective.Best Regards:
23rd Oct 2018, 11:01 PM #8Novice
- May 2012
- Brisbane
- 10
Hi,
My Sieg C6 lathe had the same crappy key on a short post, Real pain the ass.
Recently I Grabbed a suitable bolt from Bunnings and milled the bolt head to match the shape of the key, then turned down the bolt shaft to 6mm and ran a thread in it and cut it to length and cut a grove for a screwdriver in the end, It now goes through the tail stock and I can use a screw driver to get it in line with the Slot and put lock nut and a dome nut on it,
Now it is east to put the tail stock shaft back in the tail stock as the key is locked in place.
I think it needs a new tailstock
By Burner in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 31st Jul 2014, 11:56 PM -
Tailstock and Bed
By Auskart in forum THE HERCUS AREAReplies: 7Last Post: 12th Aug 2012, 10:01 AM -
Tailstock DRO
By Stustoys in forum METALWORK GENERALReplies: 58Last Post: 11th May 2011, 01:15 PM -
Indicating a tailstock
By neksmerj in forum METALWORK GENERALReplies: 0Last Post: 21st Mar 2011, 06:30 PM -
tailstock centre
By tanii51 in forum THE HERCUS AREAReplies: 5Last Post: 29th Oct 2009, 08:47 PM
