Results 1 to 15 of 20
9th Oct 2018, 01:45 PM #1Intermediate Member
- Jun 2003
- Brisbane, Qld
- 33
10mm sheet cut to size - supplier?
Hi folks,
I'm a woodworker dipping my toes into using some metal.
Looking for a set of 4 small brass, bronze, or steel plates (would have to be soft steel and not something that will rust much), about 10mm thick and 200mm*200mm. Will be used as a decorative plate joining table legs to a top (all wood otherwise).
Anyone have any ideas on where I might be able to find such a thing? I am not remotely set up to cut and finish metal like this so need it cut to size.
Thanks,
Danny
9th Oct 2018, 03:01 PM #2
Hi Danny,
Welcome to the MetalWorkForum,
You are looking for 200x 200 plate.
Crikey! If that's in steel Ok but "Soft Steel", ie mild steel /low carbon-your only option in steel will rust unless coated.Mild steel can be polished up and coated in clear and resist rust.
For that try an engineering works.
For brass or bronze, you will need another mortgage. It is expensive stuff. Your problem may be finding a retail outlet that carries this odd size and selling per metre. I have no idea where it could be found and purchased in such small quantity.
Those dimensions indicate a hugely heavy table unless you have miscalculated the sizes required.
Perhaps if you can give the blokes an idea of the table size and its weight we may be able to advise you further.
9th Oct 2018, 03:06 PM #3Member: Blue and white apron brigade
- 7,182
I agree with G, some dimensions, especially of the legs awould be useful
Unless its a really large table you won't need 10 mm thick steel for this task and probably something like 6mm should be more than enough.
I also question whether 200 x 200 is needed,
9th Oct 2018, 03:13 PM #4Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 454
Welcome to the forum Danny.
9th Oct 2018, 03:32 PM #5Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Let's not forget Aluminium as a viable option, cuts easily with woodworking tools, polishes up nicely with tools available to most woodworkers and corrosion resistant too.
9th Oct 2018, 03:40 PM #6
I'm with Karl, ally sounds like a good option. Especially when compared with brass or bronze.
Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
9th Oct 2018, 03:49 PM #7Intermediate Member
- Jun 2003
- Brisbane, Qld
- 33
It's actually a small hall/side table! Top is about 1000x300, and the legs will be about 75x75x850.
The size of the plate was an aesthetic choice rather than for structure, and I am rapidly coming to the realisation that those sizes may have been a nice idea but nowhere near worth the money!
I hadn't considered aluminium (the perils of knowing nothing about metalwork!), but the more I think about it and hunt up pricing, the more I like it.
9th Oct 2018, 04:09 PM #8Member: Blue and white apron brigade
- 7,182
9th Oct 2018, 04:50 PM #9Senior Member
- Dec 2013
- 201
Danny,
The place I use for my steel, Edcon Steel, have exactly what you have asked for, 200x200x10mm mild steel plate laser cut to size. They sell it for column bases for the construction/building industry. I often use these as a convenient source of steel plate for random projects. They have 200x200, 150x150, and in 6, 10, and 12mm thickness. The finish is plain on one face, but often has centering lines laser etched into the other face. The edges are very neat laser cut.
Edcon don't have branches in Brisbane, but I'm sure there is an equivalent supplier there, or maybe Edcon could ship to you.
Mild steel can be treated with a rust converter like phosphoric acid, and will then remain rust free for a surprising amount of time. The finish will be a mid grey, steel colour, matt finish. My main work bench is 10mm steel plate and treated thus, it only needs re-treating every couple of years despite having water, beer, wine, turps, acetone, and every other chemical found in a typical workshop spilled on it constantly. You could also clear coat over the acid treated surface for an even better finish.
Graham.
9th Oct 2018, 05:09 PM #10Intermediate Member
- Jun 2003
- Brisbane, Qld
- 33
BobL - yeah, I know structurally I am going way over the top! I am hoping to use the metal as a nice visible contrasting element between the two types of timber.
I am reaching out to a few places, I think aluminium might be the way to go as it'll be easier to drill, polish, and finish (I think!).
Many thanks to everyone who has contributed so far .
Danny
9th Oct 2018, 05:19 PM #11Most Valued Member
- 2,651
Aluminium gives a very modern look IMO, but if you want something a bit less modern then mild steel with a clear coat on it might be an option.
9th Oct 2018, 05:33 PM #12Intermediate Member
- Jun 2003
- Brisbane, Qld
- 33
This is looking like it might be a great option, they are indeed well priced at $6.60 + GST + postage - thank you Graham! Just have to work out postage cost, or see if I can find someone local who also does them.
Man, I haven't tried to work with any steel other than the thinnest sheet possible since high school - might have to remind myself how to drill into it.
Danny
9th Oct 2018, 06:15 PM #13Senior Member
- Dec 2013
- 201
9th Oct 2018, 08:09 PM #14Intermediate Member
- Jun 2003
- Brisbane, Qld
- 33
I do remember enough to slow the drill right down, clamp the workpiece thoroughly, and try to keep it lubricated - that’s it though!
9th Oct 2018, 08:48 PM #15Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
Brisbane Steel Supplies in Capalaba sells pretty much what Oldbikerider listed for Edcon Steel. Lazer cut and very neat. If you get plates that haven't been sitting there for ages and started to surface rust then they have a nice dark patina which could look good clear finished if that's what you want. I buy some from time to time for various projects.
Attempting to Join a Thin Sheet of Stainless to a Slightly Thicker Sheet?
By mattegan in forum METALWORK GENERALReplies: 7Last Post: 25th Jun 2016, 03:46 PM -
Laser cut 10mm steel pricing?
By DoctorWu in forum METALWORK GENERALReplies: 6Last Post: 19th Feb 2015, 09:34 PM -
Drilling 30mm hole through 10mm plate
By Stephen H in forum METALWORK GENERALReplies: 57Last Post: 29th Mar 2014, 12:39 PM -
How to bend 10mm or 12mm steel tube
By jabell in forum TRAILERS & OTHER FABRICATED STUFFReplies: 8Last Post: 2nd Nov 2012, 04:35 PM -
bending 10mm round bar
By Dusty Wheels in forum METALWORK GENERALReplies: 24Last Post: 22nd Aug 2007, 08:52 PM
