Results 1 to 4 of 4
Thread: why cant I cut this thread?
6th Oct 2018, 11:56 PM #1Senior Member
- Mar 2011
- Taree NSW
- 119
I have a Takisawa 1000D lathe and am attempting to cut a 16 TPI thread - I have the proper gears assembled in the gear train as shown on the info plate and the levers for threading in the appropriate position but cant seem able to cut 16 TPI
The thread chasing dial shows 24,21,20 and 18 and the appropriate alphabetical position to engage the dial - I cant understand why I cant engage anywhere as the halfnut engaging the leadscrew engages the fixed TPI leadscrew - does the fact that the chasing dial has only the numbers above mean I can only engage 24,21, 20 or 18 TPI? I am sure I haven't had this problem before so maybe I'm missing something?
7th Oct 2018, 12:25 AM #2Most Valued Member
- Jul 2016
- 35
- 1,522
What TPI is your leadscrew? a couple of photos would help a lot especially one of the screwcutting chart. With a 4 or 8 tpi leadscrew you should be able to engage at any point i believe.
8th Oct 2018, 06:14 AM #3
I can't help you with using a thread dial, but if you have the right change wheels you can cut the thread. If all else fails use the method we use in metric country:
Engage the half nuts and don't disengage before the thread is done. Reverse the lathe to rewind the tool to its start position.
Peter
8th Oct 2018, 08:00 PM #4Senior Member
- Mar 2011
- Taree NSW
- 119
My leadscrew appears to be 4mm. pitch - tomorrow I will post photos of the screwcutting chart and all charts relevant to cutting a thread on my lathe and my interpretation of them and the settings I have used to no avail. The Takisawa lathe has a possible pitch of either 4,6 or 6 TPI (4.22 pitch)
By Alf Scotting in forum METALWORK GENERALReplies: 47Last Post: 27th Oct 2018, 12:53 AM -
16 TPI thread
By BigStick in forum METALWORK GENERALReplies: 9Last Post: 3rd Dec 2015, 04:42 AM -
Best thread for All
By GSRocket in forum METALWORK GENERALReplies: 6Last Post: 11th Aug 2012, 05:02 PM -
This Thread Could Be About You!!!
By sydneyfc in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 28th Oct 2007, 09:39 PM
