Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    May 2015
    Richmond
    214
    Thumbs up
    Quote Originally Posted by Alf Scotting View Post
    O.K. guys,thanks for your input none of which has solved my problem - I was going to ask Steve if we could talk as he has the same lathe as mine but no change gears so obviously can't cut threads - I have triple checked my settings with my change gears and as I am cutting a stud without a runout groove I always retract the tool at the end and reverse the rotation direction - I just put a 20mm. piece of brass in the chuck, engaged the half nut and took a cut which gave me a groove of about 40 TPI ???My manual tells me the gear engaging the leadscrew is 24T and the panel near the halfnut engagement lever has underneath 24 the letter 'E' so I engaged at 'E' but still get 40ish TPI
    I have cut threads in the past without any problem so keep thinking I have missed something but can't think what it would be - keep thinking please fellers The calculation by old rusty toolie , I can't see its relevance to my problem
    Hi Alf. This is in your opening lines "The thread chasing dial shows 24,21,20 and 18 and the appropriate alphabetical position to engage the dial - I cant understand why I cant engage anywhere as the sprocket engaging the leadscrew (24T) engages the fixed TPI leadscrew - does the fact that the chasing dial has only the numbers above mean I can only engage 24,21, 20 or 18 TPI? I am sure I haven't had this problem before so maybe I'm missing something?" Later you mention that it is in fact a metric leadscrew.
    The relevance of the calcs was for the tracking problems which exist when cutting imperial on metric lathes and metric on imperial lathes. The 6mm leadscrew was just a sample. As you have two "threads" going on the same subject it starts to get confusing. Maybe better off locking that other one and continuing here.
    To find why you are cutting around 40 tpi when it should be 16tpi you will have to give the full story. We now know that your leadscrew is 4mm but what gears are available and what is shown on a chart to convert a selected lead on your qc gearbox to cut a 1/16" lead. Until then, we are just guessing what the problem is.
    Rusty
  2. #17
    Nov 2017
    Geelong, Australia
    57
    2,673
    Hi Alf,
    This is the chart from mine. Is yours the same?
    If I'm reading it right - mine would be 50 50 126 Gearbox #1 and B
  3. #18
    6,480
    Hi Alf,
    I would concur ! I would check that those are the gears that are actually in play.
    On my Myford there is a provision for a super fine feed, which requires a gear to be swapped.
    If I don't do that swap the gear change chart is garbage.
  4. #19
    Nov 2007
    melbourne australia
    3,228
    Same on my Hercus 260.
  5. #20
    Mar 2011
    Taree NSW
    119
    Hi Rusty and gentlemen,
    Attached photos are of the chartsimage006.jpg on my laimage004.jpgthe as proimage003.jpgmiseimage002.jpgd -still don't know where I am going wrongimage001.jpg
  6. #21
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Your chasing dial and chart are not required, as said previously leave the half nuts engaged and just reverse.
    Is the gear train set correctly.
  7. #22
    Nov 2017
    Geelong, Australia
    57
    2,673
    An earlier post stated that the gears were set to 72 68 30 120 so that would seem OK to me.
    Its a later model than mine (which is 1987). Looks nice BTW
    Getting 40tpi when set to cut 16tpi it almost seems like its in feed mode. From a general troubleshooting aspect, I'd suggest trying to cut something like 10tpi and see what happens and if there looks like a pattern (ie still roughly 3x too fine).
  8. #23
    Mar 2011
    Taree NSW
    119
    yes, triple checked - I think I have found the problem ,will check after breakfast - the lever in image002 should be to the left?
    will report back and hopefully close thread
  9. #24
    Jul 2013
    BRISBANE BAYSIDE
    90
    According to your chart, for imperial threads, both the levers in images 002 & 003 should be on the left.
  10. #25
    Mar 2011
    Taree NSW
    119
    Tried that - no difference - I have sent off an email to Takisawa, let's see if we get an answer. maybe there is a problem with the gearbox?
  11. #26
    Dec 2013
    Sydney
    201
    "No difference" This is a clue. Moving those levers should always lead to a different pitch. Are you sure you are not engaging the lever for feeds, instead of the half nuts for threading?
    Graham.
  12. #27
    Mar 2011
    Taree NSW
    119
    O.K. Rusty,
    Have done your calc. relative to my lathe and have a result of 508 - what does that do for me and where did you get your 127 over 5 from?
    have tried everything else even sent an email to Takisawa - let me have your ph. No. by private message and I will call you to discuss
    Alf
  13. #28
    Mar 2011
    Taree NSW
    119
    Not so - when I do that I can only get the traverse shaft rotating
  14. #29
    Mar 2011
    Taree NSW
    119
    Not possible - there is a lockout on my lathe where you can't engage traverse when you are trying to cut threads
  15. #30
    Mar 2011
    Taree NSW
    119
    If I do that only the traverse shaft rotates , not the leadscrew
  1. 16 TPI thread
    By BigStick in forum METALWORK GENERAL
    Last Post: 3rd Dec 2015, 04:42 AM
  2. Best thread for All
    By GSRocket in forum METALWORK GENERAL
    Last Post: 11th Aug 2012, 05:02 PM
  3. Thread changes?
    By oges in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 20th Nov 2004, 01:12 AM
