Results 1 to 14 of 14
Thread: Anyone know what this thing is?
30th Sep 2018, 07:51 PM #1Diamond Member
- Aug 2006
- 1,105
I have had this thing sitting around for over 5 years now, it came from at auction with a bunch of other stuff. It was a metal fabrication shop.
It has 3 wires Brown, blue, green so most likely runs off AC voltage. I am not game to try and plug it in yet though.
Anyone know what it is?
30th Sep 2018, 08:04 PM #2
Random guess electro magnet?
30th Sep 2018, 08:19 PM #3Most Valued Member
- 5,942
Could be a linear actuator, the big round thing would be the motor and the other long thin shaft thingy would be a ram.
Voltage would be 12 or 24 and possibly came off a hospital bed or similar.
30th Sep 2018, 08:22 PM #4
I think you could be right Dean ! The only way to be sure would be to unscrew the top and have a look inside.
I did initially think that it could be a bearing heater, looking at that wear pattern on the bottom, but can't think for the life of me why it should be on such a robust arm.Best Regards:
30th Sep 2018, 08:24 PM #5Diamond Member
- Aug 2006
- 1,105
I was thinking maybe electro magnet, but the magnets on drills that I have seen have been all sealed up, the round bit I can sorta push it in a bit and it will spring back out.
Kryn I don't think it is a linear actuator. The long shaft looks to be actual solid bar stock. If I undid the cap screw it should just slide out I would think.
30th Sep 2018, 08:57 PM #6
If you have a multimeter you could try and measure its resistance, that would give you some Idea of the voltage/current it would use. Take a reading with the probes both ways round, it might have a diode in there and that will give you two different readings.
You mentioning that the round bit at the bottom flexes, suggests that it could vibrate and be used to seat a bearing or something similar in a recess ! But the only way to find out would be to either take it apart or power it up.Best Regards:
30th Sep 2018, 09:56 PM #7Golden Member
- Jul 2011
- 837
Electro magnet as part of some sheet metal handling equipment? Feeding a press or similar?
1st Oct 2018, 05:47 AM #8
OOhh, that is worth a plug in just for the excitement. Life is more interesting on occasion that way.
1st Oct 2018, 08:57 AM #9Most Valued Member
- Jul 2016
- 35
- 1,522
Rubber gloves, squint a bit plug it in and throw a spanner at it.
1st Oct 2018, 12:18 PM #10Diamond Member
- Aug 2006
- 1,105
So I plugged it in, nothing really interesting happened, just tripped the breaker. I will have to pull it apart to investigate further.
1st Oct 2018, 08:33 PM #11
Well if nothing else, you have a bit of bar stock to play with
14th Oct 2018, 02:28 PM #12Diamond Member
- Aug 2006
- 1,105
Well just had a chance to pull it apart, it is just a limit switch. That explains why the breaker tripped when it was pushed.1539487640444~2.jpg
14th Oct 2018, 02:33 PM #13Most Valued Member
- Sep 2010
- Lebrina
- 1,910
It is the length stop from a punch and shear. You plug the wire into a receptacle on the machine and it takes the place of the foot switch. Slide the steel in until it contacts the plunger and then the machine operates, the steel drops away once cut and the machine resets.
14th Oct 2018, 02:46 PM #14Diamond Member
- Aug 2006
- 1,105
Thanks Karl, that makes sense.
http://www.assetplant.com/WebRoot/St...pact_65_29.JPG
whats this thing for please ?
By steamingbill in forum METALWORK GENERALReplies: 4Last Post: 18th Sep 2018, 02:53 AM -
what is this thing please
By steamingbill in forum METALWORK GENERALReplies: 4Last Post: 31st Aug 2018, 04:46 AM -
This a good thing or a bad thing?
By Old Hutcho in forum METALWORK GENERALReplies: 17Last Post: 5th Jan 2014, 05:36 PM -
what's this thing?
By jack620 in forum METALWORK GENERALReplies: 11Last Post: 27th Jan 2012, 12:19 PM -
what is this thing?
By 2zenmonks in forum METALWORK GENERALReplies: 13Last Post: 23rd Jun 2011, 08:17 PM
