Results 1 to 5 of 5
Thread: Lathe Chucks
29th Sep 2018, 10:05 AM #1Most Valued Member
- 4,258
Lathe Chucks
The H&F AL960 Lathe comes with a 160mm 3 jaw and 200mm 4 jaw.
Why does it not come with say both 200 3 jaw and 200 4 jaw..doesnt a 200 3 jaw suit for some reason?
29th Sep 2018, 10:35 AM #2Member: Blue and white apron brigade
29th Sep 2018, 03:06 PM #3Philomath in training
I also think it is because a 4 jaw is easy to turn the jaws around in, so it is not run with much stick out but users will run a 3 jaw with jaws way out - stops hitting things?
2nd Oct 2018, 10:42 PM #4Most Valued Member
- Australia east coast
- 2,713
Also smaller diameter chucks have higher speed ratings, the construction material being the same. 4 jaw chucks are usually holding something big/chunky and run slower.
I rarely use a 3 jaw chuck personally, don't have much use for them. Rather use a collet chuck for round bar up to 1-1/2" or a precision 4 jaw for bigger stuff/non-round work.
PDW
2nd Oct 2018, 11:39 PM #5Most Valued Member
- Healesville
- 2,129
Ditto, I only use a 3 jaw for holding hex and I don't like changing chucks.
I have started using one of these straight shank er40 collet chucks for holding small stuff, works well in the 4 jaw and only
takes a few seconds to dial it in.
https://www.ebay.com.au/itm/Precisio...AAAOSwpLNX-OE7
Where do you buy decent quality lathe chucks?
By variant22 in forum METALWORK GENERALReplies: 8Last Post: 7th Jul 2014, 10:02 PM -
Slim Lathe chucks
By Ueee in forum METALWORK GENERALReplies: 5Last Post: 19th May 2014, 09:55 AM -
Metal lathe chucks etc for upcoming TTTG sale Feb 23rd.
By clear out in forum METALWORK GENERALReplies: 4Last Post: 6th Feb 2014, 03:27 PM -
Ozmestore Lathe chucks
By Ueee in forum METALWORK GENERALReplies: 44Last Post: 26th Apr 2013, 03:05 PM -
Lathe Chucks - Appropriate Size
By Anorak Bob in forum METALWORK GENERALReplies: 13Last Post: 15th May 2011, 09:04 PM
