Results 16 to 25 of 25
27th Sep 2018, 09:57 AM #16Most Valued Member
- Jun 2012
- SA
- 1,649
Another option would be to drill out the centre of a suitable 12 mm bolt thread of correct length to 8 mm, Then turn down the plain end of your 10 mm bolt to the same diameter. Then manganese bronze braze the two together using MAPP gas (or oxy if you have it).
If you do go this way be sure to wet (tin) both surfaces with bronze and push together when hot for complete coverage/bond.
Remember that the thinner the bronze join, the stronger the bond.
Cheers RobThe worst that can happen is you will fail.
But at least you tried.
27th Sep 2018, 03:11 PM #17
just on your choice of material.
Why a HIGH tensile bolt rather than use a standard mild steel bolt, or steel rod?
Leaving aside issues of machineability, a high tensile bolt is not designed to be used as a "post"regards from Canmore
ian
27th Sep 2018, 05:13 PM #18
Hi Ian,
I was just trying to use material that was readily available to me. Bunnings seems to only stock bolts that are either stainless steel, hot dipped galvanised, some other weird tech coated bling, or this stuff (high tensile zinc coated). I chose what I thought was the lesser of the evils. Alas, they are all evil it seems.
Now I'll have to try to find 12L14 steel rod from somewhere. You'd think that would be easy in Sydney (Australia's largest city) but I have heard that sourcing stock in Australia is almost as difficult as finding a decent lathe unless you have deep pockets.
AndrewLast edited by simplicio; 27th Sep 2018 at 05:15 PM. Reason: Formatting sheesh why why why
27th Sep 2018, 05:19 PM #19
Hi Rob (xynudu?),
I don't have any brazing equipment or skills yet. Still a baby, but I'll get there one day
Andrew.
27th Sep 2018, 05:27 PM #20
Hi Dave J,
I didn't know what a helicoil was until you mentioned it, so no I haven't thought about it . Where would I get it and would it matter that the M10 is 1.5 pitch and the M12 is 1.75 pitch?
Andrew
27th Sep 2018, 05:34 PM #21Most Valued Member
Andrew,
I'm happy to make this stud and send it to you if you don't mind waiting a week.Chris
27th Sep 2018, 05:39 PM #22
27th Sep 2018, 07:42 PM #23
27th Sep 2018, 08:05 PM #24Most Valued Member
- Jun 2012
- SA
- 1,649
Hi Andrew,
We all start at the beginning and progress. It's a continual learning curve and all options are on the table.
Certainly bronze brazing is an old skill sadly neglected/overlooked by most machinists. After all why would any one want to braze when they can MIG, TIG and stick weld
Cheers Rob (Xynudu)The worst that can happen is you will fail.
28th Sep 2018, 10:59 AM #25Senior Member
- Dec 2013
- 201
Edcon Steel https://www.edconsteel.com.au/ stock 1214 free machining steel. 1 meter of 12.7mm dia will cost you under $10.00 including the cutting charge.
Graham.
How to make this ? Lathe toolpost bolt retainer
By MasterSpoon in forum METALWORK GENERALReplies: 7Last Post: 8th Aug 2017, 09:59 AM -
Jones and shipman boat anchor
By welder in forum METALWORK GENERALReplies: 6Last Post: 10th Mar 2017, 09:18 PM -
What's this bolt for?
By jack620 in forum METALWORK GENERALReplies: 3Last Post: 14th Nov 2015, 08:59 PM -
Online supplier for anchor bolts?
By WelderMick in forum METALWORK GENERALReplies: 7Last Post: 6th Aug 2013, 09:29 AM -
compond bolt down mod?
By mike rolly in forum METALWORK GENERALReplies: 8Last Post: 31st Dec 2011, 10:20 PM
