Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Tennant Creek, Aust
    61
    601
    Default Where to buy Numbers drill bits?
    I have broken a couple number drill bits, where can I buy some replacements?
    Scare as hens teeth in this part of the world.
    Dec 2013
    56
    1,418
    There are some sizes on eBay, and sets for $95.
    Other than that try your local bolt place.
    Using Tapatalk
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    Contact General Tools in Adelaide - they are a family run machine tool supply place and should be able to help you
    (no connection)
    Mar 2014
    South of Adelaide
    1,227
    +1 for general tools
    I have also purchased them from Blackwoods in the past, but i only use them when I'm desperate.
    Aug 2007
    Saskatoon, Saskatchewan, Canada
    292
    What are the number sizes you need? I might have a few extras I could send you.
    Pete
    Feb 2013
    Laidley, SE Qld
    1,039
    Metric jobber drill bits are available from the better suppliers in .05mm (.002") increments up to 3mm and in .1mm increments up to 13mm.
    In a previous life I used a lot of 11, 20, and 30 number drills, nowadays I would buy 4.9, 4.1 and 3.3mm bits.
    https://www.bolt.com.au/jobber-metri...page=1&sort=3a
    Apr 2013
    Toowoomba Qld
    401
    For my drills I tend to get them from
    https://shop.gbrengineering.com/
    also trades on Ebay as
    https://www.ebay.com.au/str/cncpoorboytoolstore
    They have a heap of drills listed, if not the ones you want can email them
    Nov 2008
    Perth WA
    6,459
    Sutton have number drills listed in their online catalogue starting at page twenty - https://s3-ap-southeast-2.amazonaws....HSS+Drills.pdf
    I am missing a few but I have found that local Perth retailers don't hold them in stock and they will only order them in a pack quantity of ten. Might be different in other parts of Australia.
    Bob.
    Dec 2007
    Adelaide
    574
    Read on another forum that number drills have not been made for quite a few years, those currently available are metric drills (nearest size) stamped as number drills, not sure if there is any truth in this.
    7,188
    Does that go for Blackwoods as well Bob?
    Blackwoods list them - the smaller numbered ones cost a bit more than the Co/TiN regular ones, the mid-range-size cost about the same and the larger ones cost about the same as standard bring drills
    Nov 2008
    Perth WA
    6,459
    To be honest Bob I have not tried Blackwoods.
    Oct 2011
    59
    6,559
    Should point out that Mark is in Tennant Creek - a distance away from nut and bolt shops, so mail order is his most likely method of supply
    Nov 2007
    melbourne australia
    3,228
    This mob has a large range of sizes. Sizes are specified in metric, but some might be number equivalents. No idea what the quality is like. http://www.hobbymechanics.com.au/pro...rills-HSS.html
    Mar 2011
    Dural NSW
    82
    1,203
    To WM460
    They can be purchased singularly from E & J Winter (Model Steam Supplies)
    P O Box 9440 Bathurst NSW 2795
    Ph 0401257758
    Fax 02 63315738
    regards
    Bruce
  15. #15
    Dec 2010
    Syd
    492
    Bought #30 and #40 singularly a couple of weeks ago at H&G hardware.....I see there's one not far from Abratool, but NT might not be so lucky!
    Short panel drills give you two bites of the cherry, but probably won't match your set. Sheetmetal, particularly aircraft trades often use them, but Tennant Creek airport didn't appear to have much if any maintenance activity.....when I was there last century iirc.
  1. drill bits (chinese)
    By robyn2839 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 22nd Apr 2018, 09:12 PM
  2. Info on drill bits.
    By Axbrigade in forum METALWORK GENERAL
    Last Post: 28th Oct 2017, 11:11 AM
  3. M35 5% Cobalt, Drill Bits.
    Last Post: 14th Nov 2015, 09:06 AM
  4. Recommended drill bits?
    By xXvapourXx in forum METALWORK GENERAL
    Last Post: 26th Sep 2012, 05:30 PM
  5. Drill bits
    By Tiger in forum METALWORK GENERAL
    Last Post: 19th Oct 2008, 11:43 PM
