Results 1 to 6 of 6
Thread: Bench drill mount.
22nd Sep 2018, 05:47 PM #1Banned
- Sep 2018
- 1
Bench drill mount.
First post:
An Aldi item that I've had my eye on for a bit took a liking to me today and I found it in the back of my car when I got home.
I really dislike bench drills due to the mess they leave behind, the space they take up also doesn't endear themselves either, so, I measured up the drill and made a pole mount for it, complete with two mounts for metric and imperial drill sets.
It sits just to the left of the Pedestal, in front of the shed central pole, the pole dissuading me from placing any machinery in front of it so it takes a space not normally used.
The dill's made of pressed steel components but otherwise seems reasonably good quality. I'll use this one for smallish holes, although it actually has a 16mm chuck???
Happy with today's effort, just got to clean up the mess now.
22nd Sep 2018, 07:07 PM #2Most Valued Member
Welcome to a Top Forum Kapala. Where abouts in Adelaide are you? Asking as we have a few members scattered around here.
24th Sep 2018, 02:09 PM #3Novice
- Aug 2009
- Sydney.
- 16
Well done. I have some square posts that could be pressed into service for vise, grinder, etc. Thanks for the post and pictures. Also, Welcome.
Michael.
24th Sep 2018, 06:51 PM #4Most Valued Member
- 70
- 1,513
First post and you ruin my Sunday plans. Instead I started on a post mount for my little Ryobi bench drill. New base from some 180 x 75 parallel flange channel is cut and drilled for the drill post. Will use another smaller piece of PFC for a new table. Mine will have a mount that is removable from the post as I do not have a shed to permanently mount it. Will try to post some pics on progress as I go. Base will also be designed to mount a chuck of some sort so I can drill the ends of bars.
Nev.
25th Sep 2018, 02:38 PM #5Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 455
Welcome to the forum.
25th Sep 2018, 04:18 PM #6
I should point out that nobody will get a reply from Kapala as I have banned this poster.
He was tohot, formerly onanon, formerly Sacc51.
Richardson E39 Bench Drill Press Restoration
By Blu_Rock in forum METALWORK GENERALReplies: 11Last Post: 28th Sep 2022, 10:17 AM -
Old Bench Drill Running in Reverse
By gazza2009au in forum ELECTRICALSReplies: 6Last Post: 29th Sep 2016, 10:02 PM -
Bench mount surface grinder
By Burner in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 3rd Sep 2014, 03:59 PM -
Waldown Hispeed bench drill
By RJT in forum METALWORK GENERALReplies: 6Last Post: 29th Sep 2012, 10:06 AM -
Old line shaft bench drill
By bollie7 in forum METALWORK GENERALReplies: 40Last Post: 13th Apr 2011, 10:04 PM
