Results 1 to 5 of 5
Thread: Wobbler for Kryn
19th Sep 2018, 10:08 PM #1Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Wobbler for Kryn
Hi Kryn I have included a pic of the bits if you need it.
I just mount it in the toolholder that happens to be in the QCTP at the time. I remove the turning tool of course.
This way it is easy to do a vertical adjustment. The crosslide takes care of the horizontal adjustment.
It isn't necessary to get the rod (machined to a point both ends) to line up perfectly with the centre in the tailstock but it helps. The key is very little to no movement at the tailstock end.
To set up just clamp the unit in the toolpost and move the carriage towards the centre punch mark until the pointed end of the rod enters the mark and a bit further to compress the spring.
Then it's normal 4 jaw practice until the tailstock end stops moving.
If my maths was better I could tell you how much the error is decreased. Many many thanks to Baron for correcting my basic error.
Yet another thing to go under the old age banner.
Phil
19th Sep 2018, 10:47 PM #2Most Valued Member
Thanks for that Phil, another nessecary project to make. I think that makes it 209 now.
20th Sep 2018, 02:35 AM #3
Hi Phil,
Personal thanks from me as well. I think I might have a suitable swivel in sight.Best Regards:
20th Sep 2018, 06:52 AM #4Most Valued Member
- Sep 2011
- Ballarat
- 3,103
20th Sep 2018, 05:35 PM #5Most Valued Member
- Healesville
- 2,129
I thought that I had seen that in my shed.......
so I had a hunt around and found this, it was with my hercus lathe odd's and end's.
Thanks Phil.
cheers, shed
Message for kryn
By chambezio in forum METALWORK GENERALReplies: 1Last Post: 14th Feb 2018, 07:53 PM -
Another Wobbler!
By bwal74 in forum METALWORK PROJECTSReplies: 1Last Post: 30th Sep 2017, 12:20 PM -
Tubal Cain Wobbler
By bwal74 in forum METALWORK PROJECTSReplies: 0Last Post: 25th Jun 2017, 08:54 AM -
SloMo Wobbler
By Dave'H in forum METALWORK GENERALReplies: 40Last Post: 12th Mar 2012, 10:57 AM -
Wobbler, dunno?
By neksmerj in forum METALWORK GENERALReplies: 4Last Post: 15th Jul 2007, 01:55 AM
