Results 1 to 9 of 9
    7,189
    Default Testing few Mics and callipers
    I was out at my former workplace today and I asked if I could borrow a 0.001mm micrometer so I could check some of my mics and callipers. I also borrowed a Mitzi digital calliper while I was at it.
    It's not what I would call a rigorous test which would involve a greater degree of cleanliness, some attempt at temp stabilised and maybe some repeated measurements
    Here is what I had to play with
    X is the Fowler 0.001mm mic from Work.
    A is a near new 150 mm ebay digital calliper that I keep at my electronics bench.
    B is a 150 mm, 6 year old calliper I bought from H&F and is my "general" shed calliper - its' pretty beat up, and after I dropped it several times, the thumbwheel on it disappeared. I also lost the battery cover on it and was using a piece of electrical tape to hold the battery in but miraculously found teh cover a few months later in a drawer.
    C is a second hand 0-2" 0.001" Mitzi mic I picked at a HTPA sale about 10 years ago. It was a bit rusty and appropriately priced. It came up OK although part of the scale is hard to read. I measured it up against another Mitzi at work and at the time it was spot on across the range .
    D is a new 300 mm ebay digital calliper I keep in my shed but I don't use it much.
    E is another H&F special that I picked up during a sale. It has not been the same since I dropped it. The readout occasionally jumps times it eventually it gives something close to the true value,
    F is a near new 25mm 0.01mm Mitzi that I use in my shed.
    G is a 200 mm ~5 year old calliper that I use a lot in my shed - It's the one I usually keep near my lathe/mill. It's been dropped few times. It no longer turns off and so says on all the time but I only need to replace the battery in it every 8-10 weeks.
    H is the Mitzi digital calliper I borrowed from work.
    For small measurements I measured individual feeler gauges while for larger measurements I used parallels. I tried as best I could to make sure the measurements were all done in the same spot on the feeler gauge or parallel but maybe I did not succeed and this may explain some of the scatter of the results.
    All measurements smaller than 25 mm are referenced to the Fowler Mic and the single ~150mm measurement (M) is referenced to the Mitzi calliper.
    (G) is a grouped set of ~6 feeler gauges to generate something thicker, I was not too careful about cleaning these so that could have contributed to the scatter.
    I was quite amazed to see that up to 25mm, apart from those G measurements, they all clustered close to the +/- 0.01mm.
    Where you don't see all 8 points it means that means some points are underneath others.
    NB the horizontal axis (Measurement) is shown as a log scale
    I should add that this level of reproducibility may not be achievable in a real workshop situation when surfaces may not as flat/smooth as feeler gauges or parallels, or one is in a hurry, dirt etc.
    When I get a chance I will explore the 25 mm and upwards range a bit more.
    6,477
    Hi Bob,
    Those measurements are about what I would expect, particularly the digital ones.
    I've several cheap digital callipers and a 10 mm precision reference. At 10 mm all my instruments would show the same scatter as yours show.
    Aug 2018
    Adelaide
    18
    Micrometers come with test bars, why don't you use them?
    Jun 2012
    SA
    1,649
    Quote Originally Posted by tohot View Post
    There's no guarantee that the test bars are actually accurate.
    I have seen Mitutoyo test bars that are not within spec.
    So much for Mitutoyo quality.
    Cheers Rob
    The worst that can happen is you will fail.
    But at least you tried.
    Mar 2012
    South Australia
    33
    Unless you have a traceable reference standard all the measurements you do are only comparitive .
    By traceable I mean a reference having a NATA endorsed report attached to it.
    Alfclp
    Jul 2012
    Griffith NSW
    435
    Quote Originally Posted by nearnexus View Post
    Cheers Rob
    What were you comparing the mitu test bars against?
    Jun 2012
    SA
    1,649
    Quote Originally Posted by scottyd View Post
    Correction - this was on ONE occasion, however it was very noticeable, hence I did the comparison.
    I checked it against several other Mitutoyo and Moore and Wright calibration cylinders/blocks from my other caliper sets.
    It was definitely out of spec (oversize) by a considerable margin - and it was an original/genuine vernier Mitutoyo micrometer, not some cheap clone.
    Nov 2007
    melbourne australia
    3,228
    Did you buy the mic new or used Rob?
    Jun 2012
    SA
    1,649
    Used. From a tool maker I know. Remember, the supplied block is oversized, not undersized from any possible wear. It is also clearly marked as per every other Mitutoyo calibration block I've seen.
  1. Cheap vernier callipers
    Last Post: 6th Aug 2017, 10:30 AM
  2. Callipers & Dividers - How big?
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 20th Jul 2014, 10:14 AM
