Results 1 to 8 of 8
Thread: Linked belt
    Jul 2008
    near Warragul, Victoria
    3,725
    Default Linked belt
    Just fitted a B \ 5L size linked belt on my Sheraton 9 lathe.
    The belt width measures around .650" it sits high in the pulley grooves
    I had a automotive style belt fitted which was a compromise, it was noisy and vibrated,
    The linked belt is quieter no doubt but dissapointingly it isn't completely vibration free.
    Been playing with speeds , the belt seems to whip up/down at all speeds.With use, it might become smoother.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Might not be taught enough.
    Jul 2008
    3,725
    Have tried tightening it but don't want to overdo it. It seems to be too wide.The pulley grooves have a strange step/ridge machined on one face.
    6,475
    Could it be a wear ridge ? I've seen pulleys with a slightly raised area a few mm from the rim, presumably from a worn or too small a belt.
    Aug 2000
    34
    I have just become the custodian of a fairly well used Sheraton 9. I haven't had a chance to put the rear drive back together yet and run it but the belt is a leather/fibre B section. It might take a day or to as weekdays are pretty crazy for me with work and kids but I can take some photos / measurements of the pulleys on mine if you want?
    As BaronJ has suggested maybe it's a wear ridge and if it's been run for a long time with the wrong section belt that may be the case. Maybe it's worth cutting a B section groove profile out of thin material and doing a comparison?
    Jul 2008
    3,725
    Default thanks
    Pic of the ridges in the groove.They appear to be originally made like that s
    Jun 2007
    sydney ( st marys )
    64
    4,890
    How close to .665" does the belt measure on the outer edge?
    6,475
    Looking at that picture, I agree they look to be machined. Not at all looking like the wear marks that I referred to earlier.
  1. Twin belt belt grinder.
    By onanonanon in forum METALWORK GENERAL
    Last Post: 18th May 2018, 03:52 PM
  2. Linked V belts
    By Swarfmaker1 in forum THE HERCUS AREA
    Last Post: 22nd Jan 2016, 06:59 PM
  3. Linked belting
    Last Post: 20th Aug 2014, 09:55 PM
  4. Replies: 18
    Last Post: 16th Jul 2013, 12:20 PM
  5. Why aren't sponsor banners linked to their website in sponsor forum?
    By Sir Stinkalot in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 23rd Apr 2013, 05:47 PM
