Results 1 to 7 of 7
Thread: question re aluminium grade
18th Sep 2018, 05:44 PM #1Senior Member
- Sep 2008
- texas, queensland
- 248
i have a set of plans from an old popular mechanics mag for building a gem faceting machine . in the plans a lot of the components it says to machine or make from "hard aluminum " question is in todays world what would i use for hard aluminum to make these parts from . and to push my luck even further any idea where i could buy it from in toowoomba in small amount as in not a full length .of course the plans are imperial just to make it a bit harder . so 3"x 1" is not going to be that it will be 75 x 25 i should think .
johno'If the enemy is in range, so are you.'
18th Sep 2018, 07:42 PM #2Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
I think they are saying stay away from 1200 grade aluminium which is quite pure and is horrible gummy stuff to machine.
6061 alloy is very common and is about all you are going to readily find. 2011 alloy machines very easily, its the aluminium equivalent of 1214L steel but you are only going to find that in rounds.
https://www.actionaluminium.com.au/w...logue-2018.pdf
18th Sep 2018, 07:59 PM #3Senior Member
- Sep 2008
- texas, queensland
- 248
i have a couple of chunks of 2011 that i bought at a swap meet a few years ago ( should of bought more but for the long carry back to the car park ). it is lovely to machine but yeah only have 2 bits of round .and it gets an oxide layer on it from what i have read and needs to be anodized .
ok so i will see where i can get 6061 from . i get most of my stuff from metals r us in toowoomba not sure what the aluminium is that they carry though ill give em a ring tomorrow .
thanks
18th Sep 2018, 09:41 PM #4Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Johno
If your in Tbar looking for Aluminium stock do yourself a favour and check out Toowoomba Metal Centre
https://toowoomba-metal-centre.business.site/
They do mostly aluminium and a bit of stainless I think
Normally much better priced than Metals R Us, $10 minimum charge and no cutting fee.
18th Sep 2018, 09:54 PM #5Philomath in training
- 6,540
5083 is not bad stuff either and pretty common in sheet/ plate.
18th Sep 2018, 09:56 PM #6Senior Member
- Sep 2008
- texas, queensland
- 248
ok ta never been in there but looks like they are in the same spot as wallers and i have been there a few times.
will be in there next tuesday then try em out .
18th Sep 2018, 10:26 PM #7Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Yeah they are straight across from Wallers, as you drive in Wallers is on the left and Toowoomba Metal is on your right.
If your from out of town but know what you want you can either call or email David at [email protected]
David will be able to give you prices and availability. If there is a bit of cutting involved I have given him an order prior and he had it all cut and ready to go when I picked it up.
P.s. when your in Wallers if you want to cringe have a look at the ways on the milling machines in their showroom. Looks like they removed the packing grease but never bothered to oil them and the ways are starting to rust up nicely.
Drilling Aluminium Question
By cava in forum METALWORK GENERALReplies: 25Last Post: 22nd Feb 2017, 09:08 AM -
Milling Aluminium - A Question
By Anorak Bob in forum METALWORK GENERALReplies: 8Last Post: 9th Jun 2016, 08:34 PM -
Any Suggestions For An Appropriate Grade Of Aluminium For Microscope Parts
By Anorak Bob in forum METALWORK GENERALReplies: 18Last Post: 25th Apr 2016, 11:09 AM -
aluminium tig question
By kelack in forum WELDINGReplies: 9Last Post: 14th Oct 2014, 09:49 PM -
welding gas for aluminium question
By northerncat in forum WELDINGReplies: 3Last Post: 14th May 2009, 02:00 PM
