Results 1 to 15 of 17
18th Sep 2018, 05:13 PM #1Golden Member
- Apr 2008
- Canberra
- 805
Name of degree scale on compound slide
Someone once told me there is no such thing as stupid questions, only stupid people. However nonetheless I need to ask what may be a stupid question- what is the name of the degree adjustment indicator on the compound slide? I.E the piece that tells you when are swung over to 30 degrees to cut a thread.
My lathe (AL340D) needs a new one as I wiped all the paint off the factory one when cleaning it with thinners once and I can barely read it now. It looks like a semi circle stainless piece that drops in place.
Brendan
18th Sep 2018, 05:29 PM #2Banned
- Aug 2018
- 18
Don't know there is a name for it, I just call it an angle indicator,,,
18th Sep 2018, 05:35 PM #3Golden Member
- Apr 2008
- Canberra
- 805
Thanks, I forgot to say the reason I need the name is so I can order (or try to order) a new one from hare and forbes.
18th Sep 2018, 06:46 PM #4Philomath in training
- 6,562
Just call it the degree scale on the cross slide. They should be able to work that out...
18th Sep 2018, 07:06 PM #5Most Valued Member
- Healesville
- 2,129
Digital Protractor
I use one of these to set the compound angles now.
https://www.ebay.com.au/itm/200mm-Di...gAAOSwa3BbXFbY
I have a square compound and so far it seems easy to set an angle and accurate enough for what I have been doing, likely more accurate than the degree scale on the cross slide.
cheers, shed
18th Sep 2018, 09:38 PM #6
The name you are looking for is "Protractor Scale" !
Shed got the name right.Best Regards:
18th Sep 2018, 11:13 PM #7Golden Member
- Apr 2018
- Drouin Vic
- 635
I was going to suggest 'azimuth', but 'protractor scale' will probably get you less blank looks.
19th Sep 2018, 06:37 PM #8Banned
- Aug 2018
- 18
I assume your lathe has an angle scale held in by bang rivets. Why not make the marks permanent with a stamped or scratched on scale.
19th Sep 2018, 08:25 PM #9
20th Sep 2018, 07:24 AM #10Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Brendan
mine fell out which is amazing as the lathe wasn't even upside down.
It is made out of aluminium and I just stuck it back in with silastic. Pity as I could have got a copy made for you.
While I have you here, I sent you a PM about the indexer.
Phil
20th Sep 2018, 09:57 AM #11
20th Sep 2018, 12:14 PM #12Most Valued Member
- Sep 2011
- Ballarat
- 3,103
20th Sep 2018, 04:14 PM #13
Hi Brendan,
Just a daft thought ! You know those cheap plastic protractors that are sold for the "Back to school" events. Would one of those do what you want ?
I've seen them in the £ shops here in the UK. In fact I bet if I look, I have one somewhere.
Yup,
Edited to add picture.Best Regards:
20th Sep 2018, 04:24 PM #14Golden Member
- Apr 2008
- Canberra
- 805
Thanks for all the replies fellas.
I like the idea of the digital angle finder - I used to have one of them actually but it didn't last long. I will buy another.
I also like the idea of getting one made in stainless - any idea who I could approach to get that done?
I spoke to hare and Forbes re a replacement. It was a very uninspiring conversation. As such I am not going to pursue ordering one through them.
Brendan
20th Sep 2018, 06:48 PM #15Most Valued Member
Hi Brendan,
I rekon that if you wanted to make your own (out of whatever material you like) then the easiest way is to measure the diameter of the circle quadrant on your compound, set up a piece of material in a rotary table, put a scribe in a collet in your mill, move the table until you are at the same circle diameter and then start scribing 1, 5, 10 etc degree marks. Advance the rotary table by the correct angle each time and scribe the next line.
Then it's a matter of trimming the material to fit your existing protractor scales on the compound.
This method would not take long, once set up.
Compound Slide
By bwal74 in forum THE HERCUS AREAReplies: 7Last Post: 10th Apr 2014, 12:20 PM -
Compound slide trouble..
By Kon R in forum METALWORK GENERALReplies: 5Last Post: 8th Jul 2012, 03:36 PM -
Free compound slide-if you can use it
By Ueee in forum METALWORK GENERALReplies: 4Last Post: 23rd Feb 2012, 10:28 AM -
How does the small compound slide come apart?
By Com_VC in forum THE HERCUS AREAReplies: 5Last Post: 1st May 2011, 01:21 AM -
Compound slide problems.
By wm460 in forum METALWORK GENERALReplies: 3Last Post: 27th Jan 2010, 08:34 AM
