Results 1 to 7 of 7
Thread: Mist coolant spray.
18th Sep 2018, 01:55 PM #1Novice
- Apr 2010
- Bundoora, Victoria
- 20
Mist coolant spray.
Hi all
Just got a mist coolant spray system. There are no instructions. I know how to use it but what pressure does it run at and how thin does the coolant need to be? Currently using 3 parts ATF to 1 part kerosene. TIA.
18th Sep 2018, 01:58 PM #2Member: Blue and white apron brigade
- 7,183
18th Sep 2018, 02:02 PM #3Novice
- Apr 2010
- 20
And does it work ok?
18th Sep 2018, 03:23 PM #4Member: Blue and white apron brigade
- 7,183
18th Sep 2018, 03:26 PM #5Novice
- Apr 2010
- 20
Thanks BobL. Setting it up as we speak. Appreciate the info.
19th Sep 2018, 10:12 AM #6Most Valued Member
I just picked up a Noga Mini Cool. It came with instructions, but there is no mention of what pressure to use. There's a couple of graphs showing air flow and coolant flow vs air pressure for various liquid types, but that's it. I think you're just supposed to adjust the air and liquid flow until you get the desired droplet size.
19th Sep 2018, 07:39 PM #7Novice
- Apr 2010
- 20
Tried it all the way down to about 10 psi through a regulator. Still sprayed sufficient lubricant for steel.
Mist Coolant systems
By BobL in forum METALWORK GENERALReplies: 37Last Post: 14th Aug 2019, 10:20 PM -
Mist Coolant
By Auskart in forum METALWORK GENERALReplies: 3Last Post: 25th Aug 2018, 02:58 AM -
Dry Moly Spray
By triden in forum GENERAL DISCUSSION / OFF TOPICReplies: 4Last Post: 7th Jun 2018, 09:46 PM -
Mist Cooling / Cutting Lubrication Question ..... ?
By RoyG in forum METALWORK GENERALReplies: 32Last Post: 9th Jul 2016, 08:28 PM -
Surface grinder kicking up mist/fog
By variant22 in forum METALWORK GENERALReplies: 18Last Post: 11th Jun 2015, 10:12 PM
