Results 1 to 13 of 13
Thread: Dawn 4” Filer Refurb.
17th Sep 2018, 05:43 PM #1
As I understand it this is an earlier model, The later model as shown in the 1967 Cat. has hardened inset jaws.
It isn’t featured in the 1969 and onwards Catalogues.
Someone I talk to in NSW has had both versions.
The jaws on mine have some inclusions on the front jaw face and are a bit rough and unequal on to. Someone has been brazing in it at some point and maybe a bit of weld on top edge of the jaws.
I’d like to have these cleaned up on a mill at some point.
Despite the beating both the handles have copped the vise seems overall in really good condition regardless of its age and the movement is quite tight with no noticeable slop.
A bit of heat from the Oxy and I should be able to improve the handles.…..Live a Quiet Life & Work with your Hands
17th Sep 2018, 05:49 PM #2
Inside of the front jaws as mentioned earlier.
The underside of the body and the jaw have a 2 & 3 stamped in them.
I haven’t figured out how two take the vice apart yet the jaw doesn’t wind all the way out it hits a stop or something I’m yet to discover.
Plan is to completely strip the vice down and give it a Birthday.…..Live a Quiet Life & Work with your Hands
17th Sep 2018, 09:27 PM #3
A photo my friend in NSW just sent me of his with ground and hardened jaws.
17th Sep 2018, 10:16 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
Id be tempted to mill both jaws out to fit hardened inserts like that top photo, itd get rid of most of that abuse and brazing too.
Good score though!
18th Sep 2018, 12:26 AM #5
I don’t have access to the equipment to do that but I think it will be my long term plan.
18th Sep 2018, 09:46 AM #6.
- 6,459
Hi Dale,
That is one nice looking vice. I imagine you have another vice and if so the filer vice could be left to fulfill its intended purpose. I have had my Record vice for close to twenty years and I don't think I have ever used it while filing without aluminium angles covering the original steel jaws.
What about a pair of solid aluminium jaws rather than hardened steel ?
Bob.
18th Sep 2018, 09:58 AM #7
I have plenty of vises & vices Bob.
I do most of my work in a Blacksmiths leg vice, I have an old crusty engineering vice for the welding bench, and a nice 4 1/2’SP Dawn engineering vice on my workbench. This was acquired for its intended purpose and will be used mostly for filing steel. Although a set of aluminium soft jaws won’t mar the work I was worried about getting steel filings imbedded and that causing marks.…..Live a Quiet Life & Work with your Hands
20th Sep 2018, 02:01 PM #8
Look straight handles, just like magic!
Even better
Light red? Not quite original 🤫
20th Sep 2018, 03:53 PM #9
Hi Dean,
I see you found the split pin
Sneaky way of stopping people taking them apart !Best Regards:
20th Sep 2018, 05:55 PM #10
Yep and it’s pretty tight in there, I also surprisingly discovered I don’t own a pair of needle nose pliers.
Although it wasn’t the split pin that was causing me issues with dismantling the vice earlier. That was a ding on the end of the front jaw slide stopping it from winding all the way out. A little draw filing remediesd the situation.…..Live a Quiet Life & Work with your Hands
25th Aug 2020, 06:23 PM #11Novice
- Jan 2008
- Sydney, NSW, Australia
- 12
DAWN FILER VICE - locking mech pics
Hi
I also have a Dawn filer in need of refurb.
Mine has the base but that is all no other parts to lock the vice to the base.
Been trying to figure out what the locking parts look like but have found no pics.
This is an old thread but woudl you perhaps have a picture or rough sketch of how the base locking mechanism works?
Thanks a bunch
26th Aug 2020, 09:55 AM #12
26th Aug 2020, 10:23 AM #13Novice
- Jan 2008
- 12
Dawn Filer
Oh yeah I see. Much simpler than I imagined. Thanks a bunch for letting me know. Cheers
dawn red
By dodge at4 in forum METALWORK GENERALReplies: 6Last Post: 18th Sep 2018, 12:34 AM -
Slotting Head As Filer?
By Anorak Bob in forum METALWORK GENERALReplies: 15Last Post: 1st Sep 2018, 10:04 AM -
An airgun refurb...
By johnbaz in forum GUNSMITHINGReplies: 20Last Post: 2nd Sep 2016, 10:17 AM -
Die Filer Clamp
By DSEL74 in forum METALWORK GENERALReplies: 3Last Post: 14th Sep 2015, 12:55 AM -
Sand Blaster Refurb Update
By Sterob in forum METALWORK GENERALReplies: 5Last Post: 6th Jan 2011, 04:36 PM
