Results 1 to 14 of 14
17th Sep 2018, 03:10 PM #1Member
- Oct 2012
- Mullaloo WA
- 80
Help required for a Chinese 13 x 40 Lathe.
Recently purchased a chinese manufactured lathe, made in 2004 with a toolbox of gears and other tools found on closer inspection after I got it home that the change gears to cut threads were missing. The closest lathe I have found that matches it is the Grizzly G0732, same controls and features but slightly different gears of course. The local distributor of the machine does not want to know, they no longer sell that model and are no help at all. Perhaps someone on the forum will be in a position to advise me, the gears I need are the 60, 120 and 127 tooth ones.
Here is a photos of one of the ones I have. It is marked M1.25 Z40, the 40 is for the number of teeth.
Any information will be gratefully received.
Col
17th Sep 2018, 09:37 PM #2Philomath in training
- 6,540
Change gears for lathes can be problematic as they are rarely available as a spare part and always seem to get separated from the machine (why? - they are not much good for anything else...)
Some of us make our own as it is not difficult if you have the equipment to do it. Can you measure up that gear? Failing anyone closer being able to do it, or being able to do it quicker I can probably make up the missing gears. I have things on my list for Kryn, China, Eric and someone else I think (Welder may be?)) and won't be able to do anything for a few months I would think but can add you on there somewhere if you like.
17th Sep 2018, 09:55 PM #3Member
- Oct 2012
- Mullaloo WA
- 80
Michael thank you muchly for your kind offer. Still trying to source some locally but if I fail I will get in touch. What i could do if we decide to go ahead is send you one of the gears I have got to help you match it.
Kind regards Col
17th Sep 2018, 11:03 PM #4Most Valued Member
- 4,887
Do you have any gear train at all at present from the headstock to leadscrew.
17th Sep 2018, 11:10 PM #5Most Valued Member
- Jul 2016
- 35
- 1,522
If you have no feeds at all i would go out and buy some timing belt pulleys and a belt, I can bore them out and put keyways in if needed.
Regards - Ralph
17th Sep 2018, 11:43 PM #6Member
- Oct 2012
- Mullaloo WA
- 80
Pipeclay and Caskwarrior, at present I have the change gears on the lathe to handle the drive to the both the lead screw and the cross feed, I also have approx 15 other gears and the only ones I am missing are the threading ones, namely 120, 127 and 60 tooth gears. When I inspected the lathe I saw a toolbox full of gears all wrapped in the original brown wax paper and stupidly assumed that all was good. The lathe was ex a high school and I expect that over the years some of the gears have been misplaced.
Thanks for your comments and suggestions, perhaps someone has a suggestion as to where to source these things.
18th Sep 2018, 01:26 AM #7Most Valued Member
- 4,887
If the 0732 you refer to is really 0782 the 120/127 is an integral part of the gear train, you must have a few gears in it as is.
Have you tried Hare and Forbes or any of the other machinery dealers on the East coast.
If you can source the change gears you will probably need the bearing and associated fittings to go with it.
I like Michael can make them for you , although I don't think I would be able to do them as cheap.
18th Sep 2018, 11:32 AM #8Member
- Oct 2012
- Mullaloo WA
- 80
Pipeclay. thanks for your reply, the gear train on the lathe atm is a 30, 100 and an 85 which is the one for feeds, I have approx 15 more cogs but none of the numbers required for thread cutting.
I would imagine that should I be able to source some I could remove the ones that are attached at the moment and plan the right ones in train so to speak.
Your offer to make some for me is much appreciated and could possibly what I have to do, what would be the approx cost please, I will firstly speak to Hare and forbes re the 120,127 gear as you are correct in that my lathe looks the same as the 0782 although the gear train is different and the manual for that lathe says it is only appropriate for the 2015 and later machines, so the search continues but now I certainly have some options thanks to you and Michael and Ralph,
18th Sep 2018, 12:05 PM #9Most Valued Member
- 4,887
Sent from my T85 using Tapatalk
18th Sep 2018, 12:07 PM #10Most Valued Member
- 4,887
Extra photo
18th Sep 2018, 12:12 PM #11Most Valued Member
- 4,887
18th Sep 2018, 03:12 PM #12Member
- Oct 2012
- Mullaloo WA
- 80
Pics of my headstock
19th Sep 2018, 06:48 AM #13Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Your lathe is perilously like mine.
Phil
20th Sep 2018, 02:49 PM #14Member
- Oct 2012
- Mullaloo WA
- 80
Pipeclay.
Yes I need the big sucker thats on your gear train and the 60 t one in the photos.
Col
Chuck for unknown Chinese lathe
By BRADFORD in forum METALWORK GENERALReplies: 7Last Post: 13th Sep 2017, 12:05 PM -
Carbide tooling Chinese lathe
By newmanwoodlands in forum METALWORK GENERALReplies: 22Last Post: 12th Jul 2014, 09:34 PM -
New Chinese Lathe
By MarkZ in forum METALWORK GENERALReplies: 13Last Post: 30th Oct 2012, 05:57 PM -
Gear Life Chinese Lathe
By barry240 in forum METALWORK GENERALReplies: 3Last Post: 15th Jun 2009, 01:06 AM -
Lathe advice required
By DavidG in forum METALWORK GENERALReplies: 5Last Post: 13th Feb 2008, 09:31 PM
