Results 1 to 9 of 9
Thread: Another Vice Handle.
16th Sep 2018, 07:49 PM #1.
- 6,458
Back in 2015 when Michael G located, purchased and forwarded me the Schaublin No.36 universal vice it was accompanied by a neat handle that Michael had very generously made for me. The handle, with a swing of 120mm, very conveniently cleared the mill's table.
I had seen photos of the original handle supplied with the vice and it, inconveniently, would not clear the table necessitating laborious removal and replacement. But the original would enable additional tightening torque so I would snug the jaws up that bit tighter with a short shifter after a close call with disaster when a workpiece slipped.
So, when I saw Gary Sneesby's No.36 vice with its handle while visiting Eccentric Engineering with Piers I took the opportunity to photograph, measure and "draw" the handle with a plan to make a pretend version. I knew Gary possessed the vice because Piers had spied it there during a visit a couple of years ago. Gary provided me with measured photos of the vice's articulated stop which I subsequently knocked together.
The original is cast iron with a screw in handle. I had a slice of 4E cast bar which I cut roughly to a suitable cross section size but overlength using a parting off tool in the shaper. I cut from both sides and snapped through the resulting web. The 12 mm square hole was cut using a file mounted in my home made slotting head. The remainder of the machine work was done mainly with the bitty Hercus rotary table then it was onto the files.
IMG_20180826_102844154 (Large).jpg IMG_20180826_105241104 (Large).jpg DSC_9909 (Large).jpg IMG_20180902_103201957 (Large).jpg IMG_20180902_164459621 (Large).jpg IMG_20180902_171756329 (Large).jpg
IMG_20180903_160827464 (Large).jpg IMG_20180903_161110380 (Large).jpg IMG_20180904_125641161 (Large).jpg
Lacking a proper radius gauge meant making do with a cut in half washer. Got there in the end. The screw in handle is 4140. The inner curve was finished with carborundum paper wrapped around a 500 mil paint tin, the closest thing to what looked like the right radius. A lathe file took care of the rest.
IMG_20180904_161320365 (Large).jpg IMG_20180904_161343166 (Large).jpg IMG_20180916_142604743 (Large).jpg IMG_20180916_135555544 (Large).jpg IMG_20180916_135629927 (Large).jpg
IMG_20180916_135645667 (Large).jpg IMG_20180916_142739077 (Large).jpg IMG_20180916_143014084 (Large).jpg
BT
16th Sep 2018, 09:09 PM #2Philomath in training
- 6,541
That's more like it!
16th Sep 2018, 09:13 PM #3.
- 6,458
16th Sep 2018, 09:33 PM #4Senior Member
- Castlemaine
- 244
Nice work BT,
No BT project is complet without your trade mark photo shot on the Waldown table. Very nice photos.
I bet out of shot there is a massive array of Swiss studio lighting, that or you photo shop your photos......
Piers
16th Sep 2018, 09:56 PM #5.
- 6,458
Nothing that flash PV.
Bare fluoros, a smear of oil on the Motorola's lens for the essential and forgiving soft focus and of course the Waldown table.
BT
17th Sep 2018, 09:21 PM #6
Wow. Ponders never showing anything he works on again in shame.
18th Sep 2018, 12:24 AM #7Most Valued Member
- Healesville
- 2,129
18th Sep 2018, 08:42 PM #8Member
- Jul 2009
- perth
- 67
Bob,
That is truly a work of art.
its unusual that the original didn't have the part you grip rotating.
The one on my schaffner vice rotates
18th Sep 2018, 09:58 PM #9.
- 6,458
Handle of the cva quill.
By welder in forum METALWORK GENERALReplies: 0Last Post: 22nd Mar 2017, 05:02 PM -
Vice Stop ( or why the vice is still not painted Michael )
By Anorak Bob in forum METALWORK GENERALReplies: 4Last Post: 5th Jan 2016, 09:01 PM -
What's the name of the handle that holds a tap?
By 19brendan81 in forum METALWORK GENERALReplies: 3Last Post: 27th Nov 2014, 01:42 PM -
Shaper vice and milling vice
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 5th Sep 2012, 12:06 AM -
vice handle with square bore
By jack620 in forum METALWORK GENERALReplies: 22Last Post: 27th Jul 2012, 10:19 AM
