Results 1 to 1 of 1
Thread: Belt tensioner fix.
16th Sep 2018, 06:02 PM #1Banned
- Aug 2018
- 18
Belt tensioner fix.
I changed the belt tensioning device on my lathe this afternoon.
Originally it had an idler on an adjustable backing, once tension was applied an allen key was used to tighten the locking bolt. I found that a PITA so changed that to the one at the of the picture some time ago. It worked ok with the bicycle wheel clamp but I also got tired of that so this afternoon fabricated one using a spring to apply tension.
Initially the idea was to pull the lever and either move the belt or replace it for the upper/lower three speeds. As luck would have it, just moving the belt over a little and spinning the chuck moves the belt so the handle is only for changing belts. Works quite well and provides for nice quick speed changes.
Belt Grinder
By eskimo in forum METALWORK PROJECTSReplies: 25Last Post: 26th May 2019, 08:45 PM -
Twin belt belt grinder.
By onanonanon in forum METALWORK GENERALReplies: 6Last Post: 18th May 2018, 03:52 PM -
flat belt
By shaper07 in forum THE HERCUS AREAReplies: 5Last Post: 29th Jun 2014, 02:55 AM -
My new belt sander
By Stustoys in forum METALWORK GENERALReplies: 8Last Post: 24th Mar 2011, 09:40 AM -
belt grip
By danielhobby in forum METALWORK GENERALReplies: 2Last Post: 5th Jun 2010, 07:01 PM
