Results 1 to 14 of 14
Thread: AL-320G longitudinal feed
16th Sep 2018, 04:40 PM #1Member
- Dec 2015
- south coast, nsw
- 52
has stopped working, something isn't engaging properly. Gone from intermittent to nil. Has anyone had the same problem and/or can suggest a plan of attack?
16th Sep 2018, 05:24 PM #2Most Valued Member
- Healesville
- 2,129
Are the gears at the end of the headstock all engauged, is the feed shaft turning?
16th Sep 2018, 06:18 PM #3Member
- Dec 2015
- south coast, nsw
- 52
16th Sep 2018, 06:47 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
I would suspect the key or shear pin that's in the worm that travels along the feed shaft. Have you had any incedents or really heavy feeds lately.
16th Sep 2018, 08:37 PM #5
In the case that your machine is a similar build to mine, consider this.
There is a pinion that engages the rack under the bed. The pinion is on a shaft that is pinned to a larger diameter gear inside the apron box. I am guessing that the pin has sheared.
pray that the pinion shaft has not bent as mine did.If so, the pinion and shaft only can be removed when the apron is moved right down past the t / stock end.
To verify the broken shear pin you will need to pull the compound and cross slide off to allow removal of the apron box lid.
IF it is similar to mine, this is what you should see. This repair was carried out back in 2009.
17th Sep 2018, 04:58 PM #6Member
- Dec 2015
- south coast, nsw
- 52
Hmmmm... This looks like a major undertaking. I spoke to H&F spares and the delivery date for any spares is at least 6 weeks, even after I pull it down and see what the problem is. That's a lot of down time and I'm flat out at the moment building up stock. I suppose I can use the half-nut for long feed, any tips on slowing that down somewhat?
17th Sep 2018, 08:23 PM #7
At this point, I would make the assumption that it is only a broken pin. It would not take a great deal of time to strip the lathe down say 2 hrs flat.
If you are lucky you can punch the broken pin out-out and replace it with one of the same diameter. I wouldn't bother with the spare part but would replace it with something soft.
If all goes well you could have it back and running in say half a day.
Mind though with the confined space you need small hands and a big heart, as they used to say.
18th Sep 2018, 11:22 AM #8Most Valued Member
- 4,890
If you put your smallest gear on the stud ( spindle ) and your largest on the screw ( leadscrew ) that will slow it down.
3rd Oct 2018, 06:21 AM #9Member
- Dec 2015
- south coast, nsw
- 52
Here's the culprit! The brass gear that engages the worm drive has stripped. Rang H&F spares and they actually have them in stock! Asked if they were commonly replaced and they agreed that that was so.
Thanks for the suggestions and help!
3rd Oct 2018, 07:07 AM #10Philomath in training
Well done on finding the problem. Remember to measure up and document the replacement as H&F may not have one next time.
3rd Oct 2018, 08:23 AM #11
I"ll second Micheal's comments.
If its possible, how about some more photos with the strip down, repair and rebuild of the break down?
In a few years, that info may welll serve as a much better guide than you had, for someone that has had the same problem with their AL-320G.
6th Oct 2018, 03:35 AM #12Member
- Dec 2015
- south coast, nsw
- 52
6th Oct 2018, 03:46 AM #13Member
- Dec 2015
- south coast, nsw
- 52
To tell the truth, once I got my ticker up and a friend around to help with a little lifting, there wasn't much in terms of complications to get in the way. Everything comes apart in a logical sequence and (almost) goes back the same way. I needed to use my fingers around the underside of the back of the saddle to find some bolts but otherwise all you need to undo pretty well stares you in the face.
6th Oct 2018, 07:45 AM #14Philomath in training
At the end of the day (provided things are keyed together properly) it probably does not matter. For home use applications either would do.
My thoughts were more along the line of measuring the replacement part up so that if H&F does not have one next time you can go to a gear manufacturer and get one made that will just drop in. You may never need it, but it beats having a machine stripped down for a few weeks waiting for a part, especially if you want to use it. Also, you never know on this forum whether someone else will post in a year or so's time that their AL-320G won't feed longitudinally...
Engaging power longitudinal/cross feed on Al960 and similar
By Hornetb in forum METALWORK GENERALReplies: 5Last Post: 5th Aug 2016, 05:49 PM -
WX#@%G AL-320G longitudinal/cross feed handle
By burraboy in forum METALWORK GENERALReplies: 6Last Post: 20th Mar 2015, 09:44 AM -
AL-320G observations
By gngh in forum METALWORK GENERALReplies: 6Last Post: 26th Jun 2013, 07:14 AM -
Engage/disengage feed levers while feed rod is rotating al960b
By Ben Dono in forum METALWORK GENERALReplies: 8Last Post: 11th Sep 2012, 08:11 PM -
Hafco AL-320G
By p10e in forum METALWORK GENERALReplies: 10Last Post: 10th Apr 2009, 08:41 PM
