Results 1 to 11 of 11
Thread: Wax Chuck !
14th Sep 2018, 07:13 AM #1
Wax Chuck !
I came across some posts on another forum a little while ago describing a "Wax Chuck" ! I must admit I had only heard of them, but upto this point never seen one. After reading about them and how versatile they can be, I decided to have a go making one and having a play with it.
So having a suitable off cut from an aluminium bar 65 mm in diameter I put it in the lathe three jaw chuck and faced it off on both sides. Now since the off cut was only about 20 mm thick, I machined a step about 5 mm deep for half the thickness.
The hole in the middle was a leftover from its previous life. It plays no part in this ! And those machining marks on the fact are not mine either. They were one of the reasons it got faced off.
This is how it looked when I had finished machining it. The step allows the chuck to be sat square up against the chuck jaws.
Now I can almost hear your thoughts ! Where is the wax ? There is non in sight.
The idea behind a wax chuck is so thin items that you wouldn't normally be able to machine, can be. It works like this, the material to be machined is secured to the face of the chuck with some kind of adhesive, in this case shellac. Now shellac will melt at about 90 to 120 degrees. By heating the chuck and coating it with shellac, the object that you want to machine can be securely attached.
Now I must confess that I've occasionally used super glue and double sided tape to stick items to the faceplate so that I can machine them, in particular, bronze thrust washers that have to be thinned and making sizing rings to fit in the bore of saw blades. I also understand that horologists use wax chucks for making watch and clock parts.
So I thought I would have a go !
I had some 2 mm thick brass sheet off cuts, so I cut a piece slightly larger than my chuck. I heated it up with a blowlamp until the shellac melted and covered the surface of the aluminium with it. Then whilst it was hot and molten, pressed the brass sheet onto the surface. I applied additional heat to the brass to make sure I had squeezed the air out. Then I let it cool. When cold I put it into the lathe chuck.
This is what the shellac looks like. This is called "Brown, button shellac". Brown because there are several grades and colours of it, depending upon what part of the world it comes from, and "Button" because when it is processed it gets stamped with a brand and looks like a button. It is used all over the world in foodstuffs, cosmetics and decorations including confectionery.
You can see from this picture that I was going to give the wax chuck a real workout, making this piece of brass plate into a round object. In fact if you look closely, the brass plate didn't quite cover the whole surface of the chuck. Indeed you can see the brown shellac just peeping out on the edge.
Well this is before and after. A nasty interrupted cut. It never even budged.
Conclusion ! A useful way of machining those, difficult to machine in any other way, parts.
Thanks Guys.Best Regards:
14th Sep 2018, 08:13 AM #2Member: Blue and white apron brigade
I like it and will be using it.
When you removed the workpiece how much shellac came away on the workpiece?
How about using outside chuck jaws, a bit safer and no step needed?
14th Sep 2018, 10:42 PM #3
Hi Bob, Guys,
First many thanks for the appreciation Guys. Good on yer !
Bob, I no longer have any outside jaws for this chuck ! Some kind soul need them more than me
As far as the shellac is concerned, its about 50, 50, you have to get it hot enough to melt the shellac, but once warm it scrapes away easily, after that meths or turps washes it off.
Just quick tip, if you do any varnishing of wood, dissolve the residue in meths to make French polish !Best Regards:
15th Sep 2018, 09:30 AM #4
Where do you get the button shellac from, all the sources I could find locally only have flakes.
15th Sep 2018, 10:48 AM #5.
- 6,459
Neat idea John.
An aside, what material are you using as a way cover under your Myford's chuck?
Bob.
15th Sep 2018, 01:37 PM #6Senior Member
- Aug 2013
- 229
On eBay search for “button shellac”
15th Sep 2018, 05:50 PM #7
https://www.ebay.com.au/itm/Shellac-....c100677.m4598
Wonder if flake shellac would do the same job, I have a mob of it sitting in a cupboard?https://www.googleadservices.com/pag...9A4IogE&adurl=
15th Sep 2018, 08:00 PM #8
Hi Gavin,
I've had mine so long I couldn't say where it came from.
As far as your flakes are concerned, why not try melting some ! A bit of plate, put a few flakes on top and heat from underneath. Just use gentle heat you don't want to set fire to them. If that works, and it should, then make a mould and make a rod of it, then you can use the stick/rod to apply it to the chuck surface.Best Regards:
15th Sep 2018, 08:05 PM #9
Hi Bob,
That is just a square of silicon rubber sheet, fastened to the cross slide. On the Myford there are some very convenient threaded holes there. I just used a couple of magnets to hold it down under the chuck. A squirt of oil now and again underneath keeps the ways clean.Best Regards:
15th Sep 2018, 09:25 PM #10
Just to finish off, I decided to face off the brass disc that I had turned using the wax chuck. I took a 0.25 mm facing cut at about 600 rpm and 8 thou feed.
This is the finish I got, I quite impressed by it.
BUT:
I tried another cut ! This time 0.75 mm deep, same 600 rpm. I managed to dislodge the workpiece. You can see how far I got before it came loose. When I lifted it off, I was surprised by how hot it was.
Moral here is to be careful how hot the work can get before the shellac melts.Best Regards:
16th Sep 2018, 01:17 PM #11Most Valued Member
- 4,258
Pile the flakes on and heat...its all the same stuff...just a different method of making the stuff.
300 mm 4 jaw chuck $50.00
By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 20th May 2016, 03:29 PM -
Chuck - what is it?
By shedbound in forum METALWORK GENERALReplies: 24Last Post: 27th Feb 2015, 10:50 PM -
collets : to chuck or not to chuck
By steamingbill in forum METALWORK GENERALReplies: 4Last Post: 26th Jul 2014, 10:17 PM -
got the chuck done
By texx in forum METALWORK GENERALReplies: 5Last Post: 30th Jul 2013, 08:31 PM -
New 3 jaw chuck
By Tiger in forum METALWORK GENERALReplies: 5Last Post: 24th Sep 2008, 10:17 PM
