Results 1 to 4 of 4
Thread: Metal Size
13th Sep 2018, 08:22 PM #1New Member
- Jan 2004
- Melbourne, Australia
- 69
- 4
Metal Size
I want to build a hoist to lift a max of 200 KG. This is the hoist that I am going to use. Hoist.jpg What size metal tube should I use if the tube will span a distance of 2m? The hoist will be located about 2m high.
13th Sep 2018, 08:42 PM #2
Is it going to span (fixed at both ends) or only supported at one end.
Using Tapatalk
13th Sep 2018, 08:45 PM #3New Member
- Jan 2004
- 69
- 4
It will have wooden 100mm x 100mm posts at both ends. The tube will be secured to the top of the posts.
13th Sep 2018, 08:53 PM #4
If that's the case you could get away with 50 x 50 x 3mm but 50x50x5mm would be better. I have the same hoist, the hoist itself is about 400mm long, so that only leaves 800mm either side.
The 2 ton engine crane I have is all 3mm and only supported on one endUsing Tapatalk
Vintage car re-metal white metal bearings
By morrisman in forum METALWORK GENERALReplies: 45Last Post: 17th Apr 2024, 07:14 PM -
Douglas Metal Shaper and Bramley Sheet Metal Folder
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 31st Jan 2016, 12:25 PM -
re; 5 to 10 mm perforated metal cut to size
By LMagic007 in forum METALWORK GENERALReplies: 3Last Post: 17th Jan 2012, 06:34 PM -
Guide to size of electrode and bead size
By Tiger in forum WELDINGReplies: 4Last Post: 10th Jul 2009, 11:45 AM -
Die size
By Howdya do that in forum METALWORK GENERALReplies: 3Last Post: 30th Jan 2008, 10:55 PM
