Results 16 to 21 of 21
12th Sep 2018, 09:50 PM #16Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
The couplers in your pictures have a built in rolled stop and would need to shortened from each end. Are they yours or are yours somehow different?
12th Sep 2018, 10:23 PM #17Most Valued Member
- Healesville
- 2,129
I dont understand why you have to use a "die set" if these are to be soldered ?
12th Sep 2018, 10:30 PM #18Most Valued Member
Need advice - Method to cut 3/8" copper couplers?
Me either shed. I’m starting to think this guy is taking the mickey
Sent from my iPad using TapatalkChris
13th Sep 2018, 02:11 AM #19Novice
- Sep 2018
- Arizona
- 10
13th Sep 2018, 10:20 AM #20Most Valued Member
- Healesville
- 2,129
Maybe it will be simpler to modify the tool or make a suitable tool to do the job than shortening all those parts.
Can you post pics of the tool and show how it operates on the part?
Cheers, shed
14th Sep 2018, 04:49 AM #21Novice
- Sep 2018
- Arizona
- 10
I think your point is valid. I've contacted my supplier and reordered. Thanks to all for the input.
Jim
Advice on a quick change tool post for a Hercus 9" ( a gift so I cannot check the fit
By Ben Dono in forum METALWORK GENERALReplies: 3Last Post: 15th Dec 2014, 07:45 PM -
Copper block idea - advice?
By Legion in forum WELDINGReplies: 8Last Post: 20th Oct 2013, 01:30 AM -
Hi-Torque Sieg SC2-L 14"x7" Dodgy Dovetail?? Advice needed.
By deppy in forum METALWORK GENERALReplies: 21Last Post: 21st Mar 2013, 05:51 PM -
Advice on 9" model A bearings
By Auskart in forum THE HERCUS AREAReplies: 6Last Post: 31st Jul 2012, 04:36 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
