Results 1 to 5 of 5
Thread: Digital caliper inaccuracy????
8th Sep 2018, 08:10 PM #1Member
- Brisbane
- 74
- 51
I have a genuine (bought from H&F) Mitutoyo 6" digital caliper. Its a few years old but little used. Investigating discrepancies between micrometer and caliper readings on a job today revealed that the caliper has become inaccurate. It measures the 25mm zero setting thingy for my 25 to 50 mm micrometer as 24.97 mm. Interestingly, my cheap calipers measure it at 25mm exactly.
Is there anything I can do to reclaim this caliper? Can it be recalibrated? Thanks in advance for any solutions.
8th Sep 2018, 08:24 PM #2Most Valued Member
- Healesville
- 2,129
you will find 2 adjustment screws at the top.
cheers, shed
8th Sep 2018, 09:42 PM #3Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
If you close the jaws and hold it up to the light you may see a slight gap between the measuring faces caused by a slight burr on the very tips of the jaws. A fine slip stone can be used to remove any raised material.
8th Sep 2018, 10:32 PM #4Philomath in training
- 6,540
There should be a button the caliper body to reset the caliper when the jaws are closed. You need to hold it in for a few seconds from memory.
However, a typical digital caliper is only usually quoted as accurate to within 0.05mm, and you are within that. If you need better accuracy then you should be measuring with a micrometer...
8th Sep 2018, 11:39 PM #5Gear expert in training
- 34
- 1,075
Yeah, there's generally a Zero button for you to reset it. I recently checked my old TESA digital against the gauge block set at work and it was showing an error of up to 0.02mm on some sizes, but perfect on others.
One of the reasons I like analogue over digital is that a physical scale is set pretty much permanently, you don't have to worry about weird encoder glitches
Outside caliper
By Michael G in forum WANTED TO BUYReplies: 10Last Post: 19th Mar 2018, 04:31 PM -
Digital UniMig 250 Multi Function Welding V's Non-Digital
By JohnSydney in forum WELDINGReplies: 3Last Post: 29th Oct 2013, 11:03 AM -
300mm dig caliper
By danielhobby in forum METALWORK GENERALReplies: 9Last Post: 17th Feb 2012, 12:44 AM -
What's a good brand of digital caliper?
By RayG in forum METALWORK GENERALReplies: 49Last Post: 1st Nov 2011, 02:12 PM -
SOLD: Digital Caliper 150mm
By krisfarm in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 1st Dec 2010, 04:43 PM
