Results 1 to 8 of 8
Thread: 3/16 W left hand thread
4th Sep 2018, 03:33 PM #1Senior Member
- Brisbane
- 143
Hi .. need to replace a broken 3/16W LH screw.. is anyone interested in making one for me ?
Ken.
4th Sep 2018, 04:06 PM #2Banned
- Aug 2018
- 18
They should be available at any bolt/nut store.
4th Sep 2018, 09:13 PM #3Most Valued Member
More details would help, such as length, head shape, unthreaded shank length, if any, etc.
5th Sep 2018, 12:49 AM #4
5th Sep 2018, 01:33 PM #5Senior Member
- Brisbane
- 143
It seems that bolt stores keep a range of LH nuts and threaded rod, but no screws or bolts !!
The pic supplied shows the broken thread in question, and as the larger thread is UNF, the thread needed is more likely to be 3/16 NC !!
The part needed will have to be approx 27mm and threaded no less than 13mm.
5th Sep 2018, 06:28 PM #6Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Re making an acceptable 3/16" LH Whitworth thread. The parts are small and handleable, so absent a suitable LH die (I don't have one) it may be possible to single point the thread in the lathe and check the fit as threading proceeds.
Not 100% sure what you need, is it the whole moveable jaw from the tap wrench?
5th Sep 2018, 09:12 PM #7Senior Member
- Brisbane
- 143
No Bob.. ..The jaw was only case hardened.. I have ground off the stub, and can now drill a hole for the new stem.. this will either be brazed or pinned in place.
As for cutting on a lathe, my machine is a dinosaur.. I do not have the gears, (esp the reverse capability) to cut a 3/16 LH thread
8th Sep 2018, 06:37 PM #8Philomath in training
- 6,559
Any luck with this one? I was at a local market the other weekend and found a tap wrench like that to replace the one I broke a while back but it cost all of $8!!.
Failing that, if you can wait another couple of months for the gods of employment to smile, I may even land a job that will let me be in the same location as my machine tools and so could make up a small length of studding for you.
Cutting a coarse left hand thread.
By Boringgeoff in forum METALWORK GENERALReplies: 52Last Post: 12th Sep 2019, 10:23 AM -
tin snips-left hand or right hand?
By 3 toed sloth in forum METALWORK GENERALReplies: 39Last Post: 18th Mar 2012, 04:07 PM -
Metric Left Hand Nut - Fine Thread
By electrosteam in forum METALWORK GENERALReplies: 3Last Post: 2nd Mar 2012, 12:41 PM -
left hand wheel studs
By leopardwood in forum METALWORK GENERALReplies: 19Last Post: 20th Jul 2010, 10:46 AM -
Left Hand Thread
By artme in forum METALWORK GENERALReplies: 17Last Post: 8th Jun 2008, 08:50 AM
