Results 1 to 6 of 6
Thread: How hot can a spindle get?
2nd Sep 2018, 07:09 PM #1Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
I have a friend who has a vertical mill, that he says gets quite hot in the spindle after running for a while.
Not just warm but hot to touch, even with no load.
It is lubricated by oil bath.
The taper roller bearings are not overly tight.
Is it normal for the spindle to get hot?
2nd Sep 2018, 07:25 PM #2Most Valued Member
- 4,887
Can he hold his hand against it or is it to hot?
2nd Sep 2018, 08:26 PM #3
As long as you can put your hand on it and not that hot you have to take it off it.
I research this many years ago and that's what is recommended.Using Tapatalk
3rd Sep 2018, 09:23 AM #4.
- 6,458
JP,
The vertical head's spindle runs very hot on my early model Hercus No.O mill. The heat is due to friction between the lipped rubber oil seals and the spindle. Seal replacement hasn't lessened the heat. In comparison the labyrinth sealed 13's head will run for hours and barely get warm.
If your friend's head is fitted with rubber seals they too may be the cause of the undue heat.
BT
3rd Sep 2018, 10:01 AM #5Mechanical Butcher
- Oct 2004
- 1,894
Thanks Fellas,
I'll pass on the info.
By the way, the mill in question is a Taiwanese, branded Huei Chang. It has taper roller bearings at the bottom of its quill.
Here's what my friend said, comparing his Huei Chang with his Bridgeport:
"I only noticed the hot spindle recently after I removed a collet and found the collet was warm. I then put my finger up the R8 hole and found it was hot! As an experiment I let it all cool down than ran it for a minute, inserted my finger and found it warm, ran it another minute, put my finger in again and found it hot enough to make me jump. I didn't wish to run it any longer as it doesn't seem right.
As an experiment I ran the Bridgeport for the same period to compare and it's R8 spindle hole was stone cold.
I think the Bridgeport uses ball races, not tapered, and I assume they are fed from an oiler above? The manual says three drops twice a day but we only use it once a week!"
I'm guessing the BP doesn't have a rubber lipped seal like the HC, maybe instead a non-contact type so it runs cooler, but also leaks a bit.
Jordan
3rd Sep 2018, 07:50 PM #6Mechanical Butcher
- Oct 2004
- 1,894
Hey Bob,
You get the cupie doll.
He did a test run with the seal removed, and it was reportedly as cool as a cucumber.
Now he's looking into low friction seals.
Jordan
spindle
By shaper07 in forum WANTED TO BUYReplies: 3Last Post: 23rd Jul 2016, 03:38 PM -
Cat 30 taper spindle
By Mike4 in forum METALWORK GENERALReplies: 4Last Post: 16th Oct 2015, 11:07 AM -
NT 30 spindle spanner
By Dave J in forum METALWORK GENERALReplies: 26Last Post: 27th Sep 2012, 06:22 PM -
Hot Spindle Bearings
By Anorak Bob in forum METALWORK GENERALReplies: 56Last Post: 10th Feb 2011, 04:32 PM -
Lathe Spindle Oil
By Swarfmaker1 in forum THE HERCUS AREAReplies: 9Last Post: 12th Jan 2011, 09:21 AM
