Results 1 to 15 of 18
Thread: Thermal Metal Spraying
1st Sep 2018, 08:00 PM #1Pink 10EE owner
- 6,218
A year back at an onsite auction I picked up a thermal metal powder sprayer. I had a few ideas, mainly fixing worn seal areas on the gear we have. Getting it done in the commercial shops was not a cheap experience. For what I though small jobs several hundred dollars would change hands.
My only problem was this runs on acetylene, and I only had LPG. With the advent of buy your own E size acetylene bottles and my general discontent with the performance of LPG on Comet3 gear, I have gone back to acetylene. I found a queensland based seller of metal spray powders https://www.metalspraysupplies.com/ , and the manufacturer of my sprayer sent me an instruction manual (it has been in production for decades https://www.ibeda.com/en/autogenous-...31-unisprayjet )
I also had to make a powder bottler as it never came with one. I printed one up on the 3D printer, complete with a 4mm pitch square thread.
With everything I needed along with instructional videos on youtube from Abom79 I gave it a whirl.
Seems to not be a very complicated process. Some practice is needed, but otherwise I think I will be able to repair my own worn parts rather then sending them out.
20180901_174328.jpg 20180901_172118.jpg 20180901_171418.jpgGold, the colour of choice for the discerning person.
1st Sep 2018, 09:02 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
How gas hungry is the process, will an E size get you many repairs?
1st Sep 2018, 09:11 PM #3Most Valued Member
Nice, so does that mean we can send clapped out lathe beds to you for rebuilding and refacing?
When your neighbours find out you can do it, you won't have to worry about farming!!!!!
Do you have a cylinderical grinder to go with it??
1st Sep 2018, 10:05 PM #4Pink 10EE owner
- 6,218
Not very hungry. It is a cold process, the job is not supposed to get over 200C.
When I get myself cloned three times yes you will
Have a cylindrical grinder here and it is reasonably set up if needed. I am not expecting much work building up parts other then my own. I am not looking for extra work to do. Maybe down the track we will see how things are going.Gold, the colour of choice for the discerning person.
2nd Sep 2018, 12:46 AM #5Golden Member
- Cairns, Q
- 666
2nd Sep 2018, 02:14 AM #6China
- Dec 2005
- South Australia
- 1,657
Many years ago I would help my uncle out at his shop on week ends, he used this method extensively to build up worn shafts and various wear plates and parts that required hard facing, he used CIG gear back then
2nd Sep 2018, 09:01 AM #7Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Nice work, and a very handy tool for your farm repairs, I am sure you will find plenty of work for it now that you have the set sorted out. When we had our foundry we used to get all of our machines shafting rebuilt by a local engineer, saved on price and down time. Sand and bearings do not mix well.
Bob
2nd Sep 2018, 09:46 AM #8
2nd Sep 2018, 12:09 PM #9Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
its a handy process. We do hot process spray metal at work. Its great until you have it nearly to finished size and find out some of it hasen't fused. Can you use the hard powders with that setup? We did some parts once that we could only machine the spray with a CBN grinding wheel.
2nd Sep 2018, 06:52 PM #10Sand and bearings do not mix well.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
3rd Sep 2018, 01:43 AM #11China
- Dec 2005
- South Australia
- 1,657
Yeh! straight into the bobbin case and hook race
3rd Sep 2018, 08:36 PM #12Pink 10EE owner
- 6,218
Had another go and ground this one
20180902_175700.jpgGold, the colour of choice for the discerning person.
4th Sep 2018, 12:11 AM #13
Is it possible to build up sheetmetal using this method? I've seen it used to deposit steel onto more solid section parts, but never on something thin.
I have some complex shaped pressed steel sheet bits which are corroded too thin to weld and repair. Making the metal that's there thicker would allow mr to restore these bits....Cheers, Joe
4th Sep 2018, 09:10 AM #14Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Richard
Not just seal areas. A loooong time ago where I did my apprenticeship we got a metal spraying kit and used it on everything. There was the main bearing housing for the crankshaft in a Vilter 6 cyl. ammonia compressor that had the bearing outer race spin, countless worn shafts, the odd stub axle and even the steering trumpet housing on a road grader.
I found that component temperature was critical, what did you use for temperature measurement.
Phil
5th Sep 2018, 10:08 PM #15Pink 10EE owner
- 6,218
Not sure Joe, the adhesion to the base metal is mechanical. They do use cold metal spraying for corrosion protection using aluminium powder and other guns use wire and different methods to melt the wire/powders like plasma or arc.
I think what was explained above was fusion metal spraying. CIG made gear for that, you heated the part white hot and sprayed a powder onto the surface and sweated it onto the surface.
I used a IR temp gun. The process has been around for quite a long time, powders today are probably better though.Gold, the colour of choice for the discerning person.
Thermal Drilling
By Pete F in forum METALWORK GENERALReplies: 10Last Post: 15th Jan 2017, 08:10 AM -
Reducing brass thermal conductivity - practical ideas?
By variant22 in forum METALWORK GENERALReplies: 20Last Post: 18th Jun 2014, 08:50 PM -
Thermal shrink fit
By Michael G in forum METALWORK GENERALReplies: 17Last Post: 15th Nov 2012, 09:29 PM -
Thermal expansion
By Legion in forum TRAILERS & OTHER FABRICATED STUFFReplies: 1Last Post: 6th Nov 2012, 06:02 PM -
Large engine metal spraying and line boring
By new_guy90 in forum METALWORK GENERALReplies: 0Last Post: 27th Feb 2012, 10:00 PM
