Results 1 to 5 of 5
    Nov 2010
    Gippsland Victoria
    733
    Default what is this thing please
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    A bad description.
    I think it is a straight shank drill arbor, where the short end is actually a jacobs taper (presses into drill chuck) and the long end can be held in a drill or lathe chuck. As it is 20mm diameter, I'm not sure exactly how (seems a bit big) or why but that is the vendor's issue.
    Nov 2010
    Gippsland Victoria
    733
    Thanks Michael.
    2nd photo makes things a bit clearer. I was searching using key word Morse Taper.
    I found cold saws in amazon.com.au once by accident - they werent called anything like cold saw and searching cold saw only finds blades. Could be various things not selling due to poorly selected keywords.
    Aug 2018
    Adelaide
    18
    I'd go along with that, some Chinese sellers seem to specialise in bad descriptors, yet others use every tag they can think of. Others will advertise something but not give critical measurements a thought.
    6,471
    I think It is closer to a B16 taper.
  1. This a good thing or a bad thing?
    By Old Hutcho in forum METALWORK GENERAL
    Last Post: 5th Jan 2014, 05:36 PM
  2. what's this thing?
    By jack620 in forum METALWORK GENERAL
    Last Post: 27th Jan 2012, 12:19 PM
  3. The modelling thing
    Last Post: 24th Oct 2011, 09:47 PM
  4. what is this thing?
    By 2zenmonks in forum METALWORK GENERAL
    Last Post: 23rd Jun 2011, 08:17 PM
  5. 11mm nut no such thing
    By 3 cav 84a in forum METALWORK GENERAL
    Last Post: 4th Dec 2009, 06:30 AM
